1 Reply Latest reply on Oct 11, 2010 6:58 AM by kglad
    The Export Frame for Classes specified in the Publish or Export settings
    auto_ghost
      I have a site I'm currently editing for a client, I'm adding a video element into it, but it doesn't play when I test movie, and when I test scene it gives me this error message:
      WARNING: The Export Frame for Classes specified in the Publish or Export settings, frame 2, does not exist. No bytecode for ActionScript 2.0 classes or interfaces was exported.
      I've heard its a bug in CS3
      Can anyone help?
      here's the actionscript:
      /**********---------- Config Part ----------**********/
      import cn.com.webstudio.util.*;
      Stage.scaleMode = "noscale";
      Stage.align = "TL";
      //Stage.showMenu = false;
      stop();
      /**********---------- Variable Part ----------**********/
      var xmlpath:String;
      var dataArr:Array = [];
      var curItem:Number = 0;
      //sound volume setting
      var volume:Number = 50;
      //buffer time setting
      var bufferTime:Number = 10;
      var locked:Boolean = false;
      //please set these fellowing value from external xml file.
      var autoPlayFirst:Boolean = false;
      var autoPlayAll:Boolean = false;
      var autoNext:Boolean = false;
      var mainStyleColor:Number = FFFFFF;
      var titleItem, videoItem, thumbList, controlItem, scrollItem;
      /**********---------- Function Part ----------**********/
      // Load the xml file.
      function loadXML(url:String, callback:Function) {
          var myxml:XML = new XML();
          myxml.ignoreWhite = true;
          myxml.onLoad = function(success) {
              if (success) {
                  if (callback != null) {
                      callback(this);
          myxml.load(url);
      if(xmlpath !== undefined ){
      loadXML(xmlpath, parseXML);
      }else{
       loadXML("config.xml",parseXML);
      // parse xml data
      function parseXML(xml:XML) {
          curItem = -1;
          dataArr = [];
          var i, j, temp1, temp2, temp3;
          temp1 = xml.firstChild.firstChild.childNodes;
          // config part
          autoPlayFirst = temp1[0].firstChild.nodeValue=="false";
          autoPlayAll = temp1[1].firstChild.nodeValue=="true";
          autoNext = temp1[2].firstChild.nodeValue=="true";
          mainStyleColor = int(temp1[3].firstChild.nodeValue);
          // item data
          temp2 = xml.firstChild.childNodes[1].childNodes;
          for (i in temp2) {
              dataArr[i] = {};
              temp3 = temp2[i].childNodes;
              for (j in temp3) {
                  dataArr[i][temp3[j].nodeName] = temp3[j].firstChild.nodeValue;
          init();
      function init() {
          // title item
          titleItem = this.attachMovie("titleItem", "titleItem", 1);
          titleItem._x = 68;
          titleItem._y = 21;
          // video list
          videoItem = this.attachMovie("videoItem", "videoItem", 2);
          videoItem._x = 68;
          videoItem._y = 50;
          videoItem.posX = videoItem._x;
          videoItem.posY = videoItem._y;
          videoItem.posW = videoItem._width;
          videoItem.posH = videoItem._height;
          // thumb list
          thumbList = this.attachMovie("thumbList", "thumbList", 3);
          thumbList._x = 558;
          thumbList._y = 20;
          // control item
          controlItem = this.attachMovie("controlItem", "controlItem", 4);
          controlItem._x = videoItem._x-1;
          controlItem._y = videoItem._y+videoItem._height+11;
          controlItem.posX = controlItem._x;
          controlItem.posY = controlItem._y;
          //controlItem.volBut.onPress();
          // scroll item
          scrollItem = this.attachMovie("scrollItem", "scrollItem", 5);
          scrollItem._x = thumbList._x+thumbList._width-scrollItem._width+3;
          scrollItem._y = thumbList._y+thumbList.mask._y;
          // set main style color
          setStyle();
      function setStyle() {
          wEffect.setRGB(thumbList.back, mainStyleColor);
          wEffect.setRGB(controlItem.back, mainStyleColor);
          wEffect.setRGB(titleItem.back, mainStyleColor);
