2 Replies Latest reply on Oct 11, 2010 5:09 AM by Praveen Kumar Indupuri
    Flex Unit 4 Doesnt wor with AS4 Mock
    Praveen Kumar Indupuri Level 1
      Wehen I run the Mock 4 AS script with the Flex Unit 4 I get the dblow error.
      ArgumentError: Error #1063: Argument count mismatch on org.mock4as.samples.publisher::PublisherTest
      at flexunit.framework::TestSuite(TestSuite.as:124)
      at org.flexunit.internals.runners::FlexUnit1ClassRunner/createTestSuiteWithFilter(FlexUnit1C lassRunner.as:167)
      at org.flexunit.internals.runners::FlexUnit1ClassRunner(FlexUnit1ClassRunner.as:100)
      at org.flexunit.internals.builders::FlexUnit1Builder/runnerForClass(FlexUnit1Builder.as:60)
      at org.flexunit.runners.model::RunnerBuilderBase/safeRunnerForClass(RunnerBuilderBase.as:63)
      at org.flexunit.internals.builders::AllDefaultPossibilitiesBuilder/runnerForClass(AllDefault PossibilitiesBuilder.as:106)
      at org.flexunit.runners.model::RunnerBuilderBase/localRunners(RunnerBuilderBase.as:119)
      at org.flexunit.runners.model::RunnerBuilderBase/runners(RunnerBuilderBase.as:87)
      at org.flexunit.runners::Suite(Suite.as:170)
      at org.flexunit.runner::Request$/classes(Request.as:201)
      at Function/http://adobe.com/AS3/2006/builtin::apply
      at org.flexunit.runner::FlexUnitCore/runClasses(FlexUnitCore.as:191)
      at org.flexunit.runner::FlexUnitCore/run(FlexUnitCore.as:171)
      at flexunit.flexui::FlexUnit4TestRunner/run(FlexUnit4TestRunner.as:75)
      at flexunit.flexui::FlexUnitTestRunnerUI/runWithFlexUnit4Runner(FlexUnitTestRunnerUI.mxml:14 8)
      **[ at FlexUnitApplication/onCreationComplete(FlexUnitApplication.mxml:22) ]
      **[ at FlexUnitApplication/___FlexUnitApplication_Application1_creationComplete(FlexUnitApplicat ion.mxml:7) ]
      at flash.events::EventDispatcher/dispatchEventFunction
      at mx.core::UIComponent/dispatchEvent(UIComponent.as:12266)
      at mx.core::UIComponent/set initialized(UIComponent.as:1577)
      at mx.managers::LayoutManager/doPhasedInstantiation(LayoutManager.as:759)
      at mx.managers::LayoutManager/doPhasedInstantiationCallback(LayoutManager.as:1072)
      How can I resolve this error.
        • 1. Re: Flex Unit 4 Doesnt wor with AS4 Mock
          mlabriola Level 4
          i noticed that you error message includes flexunit.framework.testsuite? it also says that you are using the flexunit one runner. this means that your code is extending from testcase and testsuite meaning that, while you are using flexunit four to run these tests, you are still writing flexunit one style tests.
          either the flexunit or mockas team may have a bug, but i am not sure if that project is intended to work with flexunit one. can you post a code snippet that shows the issue?
          • 2. Re: Flex Unit 4 Doesnt wor with AS4 Mock
            Here is code snippet I am using
            package org.mock4as.samples.publisher
            import flexunit.framework.TestCase;
            import org.mock4as.Mock;
                public class PublisherTest extends TestCase
            public function PublisherTest(methodName : String){
                        super(methodName);
            public function testOneSubscriberReceivesAMessage():void{
            // create the mock
            var mockSubscriber:MockSubscriber = new MockSubscriber();
            const MSG:String = "MESSAGE";
            // set expectations
            mockSubscriber.expects("receive").times(1).withArg(MSG).noReturn();
            // inject the mock
            var myPublisher:Publisher = new Publisher();
            myPublisher.add(mockSubscriber);
            // execute
            myPublisher.publish(MSG);
            // verify mock behavior
            mockSubscriber.verify();
            // show mock expectation error message if any
            assertNull(mockSubscriber.errorMessage());
            // Inner Class
            import org.mock4as.samples.publisher.ISubscriber;
            class MockSubscriber extends Mock implements ISubscriber {
            public function receive(message:String):void
            record("receive", message);
