0 Replies Latest reply on Jul 16, 2007 7:38 PM by oneofhero
    using actionscrpt and return a value
    oneofhero
      In my source code, I try to post a xml file on a api. Then the server send back to flash. myLoader.data will contain the response from the server. I can see the myLoader.data in xmlloaded function has the data that i needed. I try to return the xml file back to the Test1(main) function. How can I do it? By the way, the getXML function does not work.
      package {
      import flash.display.Sprite;
      import flash.events.*;
      import flash.net.*;
      public class Test1 extends Sprite {
      private var myLoader:URLLoader = new URLLoader();
      var myXMLURL:URLRequest = new URLRequest(" some api");
      public function Test1() {
      //add xml data in the myXMLURL
      myXMLURL.contentType ="text/xml";
      myXMLURL.method = URLRequestMethod.POST;
      myXMLURL.data = "<?xml version=\"1.0\"?><!DOCTYPE REQUEST SYSTEM ......";
      myLoader.addEventListener(Event.COMPLETE, xmlLoaded);
      myLoader.load(myXMLURL);
      trace(getXML());
      //some action after the xml file return form the server
      private function xmlLoaded(event:Event):XML{
      return XML(myLoader.data);
      private function getXML():XML{
      return myLoader.data;
