2 Replies Latest reply on Oct 12, 2010 8:07 AM by cmeira
    Converting CR2 to DNG via script?
    cmeira Level 1
      Hello,
      I want to create a script which converts several CR2 files as DNGs (later to create a drag'ndrop-button for this script).
      It's not possible to record this steps/these steps. Probably because of the "Camera Raw" module which Photoshop uses after opening a CR2 file.
      Thanks.
      Carlos
        • 1. Re: Converting CR2 to DNG via script?
          Paul Riggott Level 6
          You might be better using the stand-alone free DNG converter from Adobe..
          http://www.adobe.com/products/dng/
          With this you can do a folder of raw files.
          You could even create a batch file do do the convert IE:
          Create a .bat file with something on the lines of..
          For %%a in (c:\CR2\*.cr2) do "C:\Program Files\Adobe\Adobe DNG Converter.exe" -d c:\DNG %%a
          This will process all cr2 files in Folder C:\CR2 and convert them to DNG putting them in C:\DNG
          Another possibility would be to create a script passing the command line to the app.system() command (CS4/5)
          • 2. Re: Converting CR2 to DNG via script?
            cmeira Level 1
            Strange, that the app.system()-command is undocumented...
            But I created a link to "Adobe DNG Converter.exe" in the sendto-folder (using win7). So I can convert my CR2 files by using the context menu and then hitting the enter key -- these few steps are OK for me and more comfortable then using the RAW converter via Photoshop.
            Thanks a lot!
