6 Replies Latest reply on Oct 12, 2010 2:59 AM by riddler275
    Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
    riddler275
      This problem has been driving me crazy all day...
      I installed the patch to opgrade Adobe Reader 9.3 into 9.4 this morning; as soon as I did I was unable to open PDFs, getting an error message along the lines of "you are not authorised to view this".  To try and resolve this, I uninstalled reader and installed it again directly from the Adobe website.
      I'm now getting the following error:
      "This action (i.e. opening the file) is only valid for products that are currently installed".
      I uninstalled and reinstalled twice more, same issue.
      I have tried repairing the installation in Adobe.  To clarify, I can't double click/right click open PDFs.  However, if I drop them onto the Adobe Desktop icon they open normally.  I am also unable to open PDFs which are attached to emails without dropping them on desktop, then dropping them on Adope icon.
      I'm using 64 bit Windows 7, and it is my work desktop that is affected.
      Does anyone have any advice?
        • 1. Re: Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
          Ankit_Jain Adobe Employee
          Looks like the association to your .pdf files has been changed or has been altered incorrectly for some reason.
          Can you please try the following steps to rectify the same:
          1. Click on the Start button.
          2. In the right hand menu click on default programs.
          3. In the window that opens up, click on "Associate a file type or or protocol with a program".
          4. That will open a list of file extensions such as .pdf etc.  Double click on the .pdf extension
          5. A window will open giving you a choice of programs to choose from.
          6. Click on the browse button. Scroll through the folder structure and select AcroRd32.exe from the appropriate installation directory. (By Default it would be located at C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe unless you have installed it at some other location.)
          Hope that works out successfully for you.
          Ankit
          • 2. Re: Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
            thelakers Level 1
            I'm having the same problem.
            When I get to the "Assocaiate a file type... with a program" screen, .pdf is not listed.
            In addition, after "successfully" installing Reader 9.4 from the Adobe site, I cannot see it in my Program Files folders.
            I am running Windows7 64bit.  I just opened pdf files from this PC last week.
            • 3. Re: Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
              LeoAdobeX Adobe Employee
              On 64bit systems Adobe Reader is installed under C:\Program Files (x86)\Adobe
              To see if it is properly installed use Control Panel\Programs\Programs and Features
              • 4. Re: Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
                thelakers Level 1
                I tried to download/install 9.4 again.
                Got the same error message again (see below) followed by, "Installation Complete".  Still not showing in Program Files (x86) or in Control Panel\Programs...  So i guess it's not really Installed.
                The error message I get at 99.9% is:
                "Error 1406.Could not write value to key \Software\Classes\CLSID\{98D9A6F1-4696-4B5E-A2E8-36B3F9C1E12C}\LocalServer32.  Verify that you have sufficient acess to that key, or contact your support personnel."
                Any ideas please?  Should this be a new thread?
                • 5. Re: Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
                  Well seems now you are stuck with 2 different problems at once..
                  To tackle the first problem i.e. your PDFs not opening on double click. Can you right click on any PDF and click on the "Open With... > Choose Default Program" option. (Incase, the option doesnt appear in the context menu, try holding "Shift" and then right clicking the PDF file). In the dialog box that appears, click "Browse" and locate the AcroRd32.exe at "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe". Make sure that "Always use the selected program to open this kind of file" checkbox is checked. Click OK to close all windows.
                  Now try executing the instructions in the previous post, the .PDF extension will be visible to you in the "Associate a file type or or protocol with a program" dialog box.
                  As far as the second problem goes, i.e. your installation failing cause of error 1406, Can you please try out the below mentioned steps:
                  1. Download Microsoft's SubinACL tool from http://www.microsoft.com/downloads/details.aspx?FamilyID=e8ba3e56-d8fe -4a91-93cf-ed6985e3927b&displaylang=en
                  2. Install the same by double clicking on the "subinacl.msi" just downloaded.
                  3. Open Command Prompt window through the Run Dialog Box (Start -> Run and type "cmd" and click OK)
                  4. In the Command Prompt window, type in the following commands:
                      i. cd /d "%ProgramFiles%\Windows Resource Kits\Tools" (Hit Enter)
                     ii. subinacl  /subkeyreg  HKEY_LOCAL_MACHINE\\Software\Classes\CLSID\{98D9A6F1-4696-4B5E-A2E8-36B3F9C1E12C}\LocalServer32 /grant=administrators=f /grant=SYSTEM=f /grant=USERS=f  /grant="Creator Owner"=f (Hit Enter)
                    iii. subinacl  /subkeyreg  HKEY_CURRENT_USER\\Software\Classes\CLSID\{98D9A6F1-4696-4B5E-A2E8-36B3F9C1E12C}\LocalServer32 /grant=administrators=f /grant=SYSTEM=f /grant=USERS=f  /grant="Creator Owner"=f (Hit Enter)
                  For more details please have a look at the below post:
                  http://forums.adobe.com/message/3080878#3080878
                  Hope all this works out..!!!
                  Ankit
                  • 6. Re: Unable to open documents in Adobe Reader 9.4 - showing as not 'currently installed'?
                    riddler275 Level 1
                    Hi Ankit,
                    Thank you for your advice, but Im still having problems.
                    Back to the OP.  To avoid the threads getting confused, I suggest the other user starts a new one?
                    I have tried ensuring that PDFs are automatically opened by Adobe.  I used the path you suggested.  However, I'm still having the same problem.
                    When I went to do this, Adobe was listed in the "recommended" list of products with which to open PDF files.  However, I ignored this and followed your guidance.  Once I had done, nothing happened (i.e. Adobe icon was not added to the 'Other products' list below the 'Recommended').
                    To me, this speaks of either a bad installation or bad association in which something is causing Adobe not to recognise itself.
                    What else can you advise?
                    Is there, for instance, a way to have a clean removal of Adobe, and then reinstall?  I don't even know if this will work.
