14 Replies Latest reply on Oct 12, 2010 12:00 PM by Diane_234
    Submit button generates and sends to multiple addresses, but with error message
    Diane_234
      I was successful in manually adding the code to generate multiple addresses to an e-mail:
      This is the code:
      <event activity="click">
                     <submit format="pdf" target="mailto:david.kropf@ucr.edu; andrea.kaus@ucr.edu; martha.ponce@ucr.edu" textEncoding="UTF-16" xdpContent="pdf datasets xfdf"/>
                  </event>
      This is the error message when opened with reader:
      "The document was altered since its creation and the use of "extended features" is no longer available."
      I double checked the "extended features" setting BEFORE I sent the document and this is the message I received:
      "The document already has enabled usage rights in Adobe Reader.
      To remove Reader Enablement, use File>Save a Copy."
      I did not choose to remove enablement.
      Additionally, someone else said to separate the e-mail addresses with commas, but this is the error message it produced:
      So, to reiterate, I'm having trouble regardless if I separate the e-mail addresses with semi-colons or commas.
