3 Replies Latest reply on Dec 20, 2010 12:35 AM by Fredbloggsx2
    Installing Premiere 9 on MAC
    kmb08
      Anybody else having problems installing Premiere elements 9 on a MAC using disc?  Was able to install Elements 9 but can't get Premiere to download.  Been on hold with Adobe for 58 minutes.  Help!
        • 1. Re: Installing Premiere 9 on MAC
          Fredbloggsx2
                    Have just had Elements 9 and Preiere Elements 9 delivered.
                    Elements 9 installed without any problem.  Premiere Elements 9 threw out the disc four times in succession with message
          I followed the route advised through Library/Logs/Adobe/Installers and gave up when I got the following:-
          [       0] Fri Nov 26 18:16:59 2010  INFO
          Visit http://www.adobe.com/go/loganalyzer/ for more information
          START - Installer Session
          RIBS version: 3.5.8.0
          OSX version: 10.6.5
          ::START TIMER:: [Total Timer]
          CHECK: Single instance running
          CHECK : Credentials
          Load Deployment File
          Create Required Folders
          Assuming install mode
          ::START TIMER:: [Bootstrap]
          Perform Bootstrapping ...
          :: END TIMER :: [Bootstrap] took 6553 miliseconds (6.553 seconds) DTR = 1.22081 KBPS (0.0011922 MBPS)
          Looking up install source path
          Sync Media DB ...
          ::START TIMER:: [Sync Media DB]
          Pre check media db sync
          End of Pre check media db sync. Exit code: 0
          :: END TIMER :: [Sync Media DB] took 3363 miliseconds (3.363 seconds) DTR = 161.76 KBPS (0.157969 MBPS)
          Ready to initialize session to start with ...
          ::START TIMER:: [CreatePayloadSession]
          -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
          Updated source path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content
          Updating media info for: {07CE3591-3679-4058-8552-44A2F23613B8}
            Type: 1, Volume Order: 1, Media Name: PRE 9 Content
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPacken_US/LangPacken_US.dmg
          Updating media info for: {0CB26B3E-89DB-405a-BB45-181C4D686735}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackja_JPHD/LangPackja_JPHD.dmg
          Updating media info for: {2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/Presets/Presets.dmg
          Updating media info for: {493D60D7-D8F7-470b-B947-F9B380604158}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackde_DE/LangPackde_DE.dmg
          Updating media info for: {59F0B800-D041-4120-A1B0-2EEBBF3FF79D}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackHDOther/LangPackHDOther.dmg
          Updating media info for: {5B8918FC-A624-4fed-9744-CA0815BCFB6F}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackja_JPCommon/LangPackja_JPCommon.dmg
          Updating media info for: {651B14E1-BDA4-4AD2-B1D3-094FFE9AEA2D}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackCommonOther/LangPackCommonOther.dmg
          Updating media info for: {787DB784-57FF-4983-A8A6-1F2048E9AA68}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackja_JPPresets/LangPackja_JPPresets.dmg
          Updating media info for: {78C17FAA-2368-4505-BED6-C6F56F923AE0}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/SD/SD.dmg
          Updating media info for: {7B4033B9-FD8F-4014-9CA4-F433E1E6242A}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackja_JP/LangPackja_JP.dmg
          Updating media info for: {81B0CE07-2DA2-4c59-BA46-BC81E0656491}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/HD_SD_Common/HD_SD_Common.dmg
          Updating media info for: {848B005A-4D0D-4A60-8F82-34F55781C65A}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackPresetsOther/LangPackPresetsOther.dmg
          Updating media info for: {861E2110-16F6-4E67-87F0-AF11332A4599}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackSDOther/LangPackSDOther.dmg
          Updating media info for: {A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/HD_STI/HD_STI.dmg
          Updating media info for: {A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/PreMacContentInstaller/PreMacContentInstaller.dmg
          Updating media info for: {C3471B20-2622-4856-BF95-A47C45EBF54B}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackja_JPSD/LangPackja_JPSD.dmg
          Updating media info for: {DAEF6A42-EE5A-47c1-B3D5-A0488F06BB29}
            Path: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content/payloads/LangPackfr_FR/LangPackfr_FR.dmg
          --------------------  END  - Updating Media Sources -  END  --------------------
          Supported RIBS version range: [0.0.66.0,3.5.8.0]
          ----------------- CreatePayloadSession: machine is x86 ---------------
          ______ Verify Dependency Subscribers ______
          Setting property "INSTALLDIR" to: /Library/Application Support/Adobe/Premiere Elements/9/Content
          Setting property "installLanguage" to: en_US
          Attempting to find the selected language in the set of available payload languages
          Setting property "installSourcePath" to: /Volumes/PRE 9 Content/Adobe Premiere Elements 9 Content
          Overwrite property "userASUPath" to: /Users/ericdalzell/Applications/Adobe/OOBE/PDApp
          Found payload actions:
          Deciding what installer mode to use...
          BEGIN Setting requested payload actions
          Value returned on lookup of payload: {81B0CE07-2DA2-4c59-BA46-BC81E0656491} Common is: false
          Action string for  {81B0CE07-2DA2-4c59-BA46-BC81E0656491} Common  is none
          Value returned on lookup of payload: {5B8918FC-A624-4fed-9744-CA0815BCFB6F} Common_LangPackja_JPCommon is: false
          Action string for  {5B8918FC-A624-4fed-9744-CA0815BCFB6F} Common_LangPackja_JPCommon  is none
          Payload {5B8918FC-A624-4fed-9744-CA0815BCFB6F} Common_LangPackja_JPCommon is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {651B14E1-BDA4-4AD2-B1D3-094FFE9AEA2D} Common_LangPackCommonOther is: false
          Action string for  {651B14E1-BDA4-4AD2-B1D3-094FFE9AEA2D} Common_LangPackCommonOther  is none
          Payload {651B14E1-BDA4-4AD2-B1D3-094FFE9AEA2D} Common_LangPackCommonOther is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7} Presets is: false
          Action string for  {2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7} Presets  is none
          Value returned on lookup of payload: {787DB784-57FF-4983-A8A6-1F2048E9AA68} Presets_LangPackja_JPPresets is: false
          Action string for  {787DB784-57FF-4983-A8A6-1F2048E9AA68} Presets_LangPackja_JPPresets  is none
          Payload {787DB784-57FF-4983-A8A6-1F2048E9AA68} Presets_LangPackja_JPPresets is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {848B005A-4D0D-4A60-8F82-34F55781C65A} Presets_LangPackPresetsOther is: false
          Action string for  {848B005A-4D0D-4A60-8F82-34F55781C65A} Presets_LangPackPresetsOther  is none
          Payload {848B005A-4D0D-4A60-8F82-34F55781C65A} Presets_LangPackPresetsOther is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0} HD is: false
          Action string for  {A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0} HD  is none
          Value returned on lookup of payload: {0CB26B3E-89DB-405a-BB45-181C4D686735} HD_LangPackja_JPHD is: false
          Action string for  {0CB26B3E-89DB-405a-BB45-181C4D686735} HD_LangPackja_JPHD  is none
          Payload {0CB26B3E-89DB-405a-BB45-181C4D686735} HD_LangPackja_JPHD is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {59F0B800-D041-4120-A1B0-2EEBBF3FF79D} HD_LangPackHDOther is: false
          Action string for  {59F0B800-D041-4120-A1B0-2EEBBF3FF79D} HD_LangPackHDOther  is none
          Payload {59F0B800-D041-4120-A1B0-2EEBBF3FF79D} HD_LangPackHDOther is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {78C17FAA-2368-4505-BED6-C6F56F923AE0} SD is: false
          Action string for  {78C17FAA-2368-4505-BED6-C6F56F923AE0} SD  is none
          Value returned on lookup of payload: {C3471B20-2622-4856-BF95-A47C45EBF54B} SD_LangPackja_JPSD is: false
          Action string for  {C3471B20-2622-4856-BF95-A47C45EBF54B} SD_LangPackja_JPSD  is none
          Payload {C3471B20-2622-4856-BF95-A47C45EBF54B} SD_LangPackja_JPSD is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {861E2110-16F6-4E67-87F0-AF11332A4599} SD_LangPackSDOther is: false
          Action string for  {861E2110-16F6-4E67-87F0-AF11332A4599} SD_LangPackSDOther  is none
          Payload {861E2110-16F6-4E67-87F0-AF11332A4599} SD_LangPackSDOther is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {A85C9905-3D8E-41FF-A031-15DB7EFFA6E5} PreMacContentInstaller is: false
          Action string for  {A85C9905-3D8E-41FF-A031-15DB7EFFA6E5} PreMacContentInstaller  is install
          Value returned on lookup of payload: {DAEF6A42-EE5A-47c1-B3D5-A0488F06BB29} PreMacContentInstaller_LangPackfr_FR is: false
          Action string for  {DAEF6A42-EE5A-47c1-B3D5-A0488F06BB29} PreMacContentInstaller_LangPackfr_FR  is none
          Payload {DAEF6A42-EE5A-47c1-B3D5-A0488F06BB29} PreMacContentInstaller_LangPackfr_FR is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {7B4033B9-FD8F-4014-9CA4-F433E1E6242A} PreMacContentInstaller_LangPackja_JP is: false
          Action string for  {7B4033B9-FD8F-4014-9CA4-F433E1E6242A} PreMacContentInstaller_LangPackja_JP  is none
          Payload {7B4033B9-FD8F-4014-9CA4-F433E1E6242A} PreMacContentInstaller_LangPackja_JP is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {493D60D7-D8F7-470b-B947-F9B380604158} PreMacContentInstaller_LangPackde_DE is: false
          Action string for  {493D60D7-D8F7-470b-B947-F9B380604158} PreMacContentInstaller_LangPackde_DE  is none
          Payload {493D60D7-D8F7-470b-B947-F9B380604158} PreMacContentInstaller_LangPackde_DE is extension payload. Aligning its action according to parent.
          Value returned on lookup of payload: {07CE3591-3679-4058-8552-44A2F23613B8} PreMacContentInstaller_LangPacken_US is: false
          Action string for  {07CE3591-3679-4058-8552-44A2F23613B8} PreMacContentInstaller_LangPacken_US  is none
          Payload {07CE3591-3679-4058-8552-44A2F23613B8} PreMacContentInstaller_LangPacken_US is extension payload. Aligning its action according to parent.
          END Setting requested payload actions
          Collected advanced path check information for INSTALLDIR
          INSTALLDIR is a well-formed path
          INSTALLDIR is not the root path
          INSTALLDIR is on a local volume
          INSTALLDIR is on a writable volume
          INSTALLDIR is not on a case sensitive volume
          INSTALLDIR passed path basic path validation: /Library/Application Support/Adobe/Premiere Elements/9/Content
          [       0] Fri Nov 26 18:17:00 2010  INFO
          ::START TIMER:: [System check :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}]
          Custom action return code: 0
          :: END TIMER :: [System check :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}] took 47 miliseconds (0.047 seconds)
          ::START TIMER:: [System check :{2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}]
          :: END TIMER :: [System check :{2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}] took 0 miliseconds (0 seconds)
          ::START TIMER:: [System check :{A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}]
          :: END TIMER :: [System check :{A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}] took 1 miliseconds (0.001 seconds)
          ::START TIMER:: [System check :{78C17FAA-2368-4505-BED6-C6F56F923AE0}]
          :: END TIMER :: [System check :{78C17FAA-2368-4505-BED6-C6F56F923AE0}] took 4 miliseconds (0.004 seconds)
          ::START TIMER:: [System check :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}]
          :: END TIMER :: [System check :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 1 miliseconds (0.001 seconds)
          Payloads passed preflight validation.
          [       0] Fri Nov 26 18:17:01 2010  INFO
          Call PreSession Custom Hook
          ::START TIMER:: [Pre session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}]
          In InstallSessionOpenProc
          In InstallPreSystemCheckProc
          :: END TIMER :: [Pre session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 9 miliseconds (0.009 seconds)
          Calling the custom action code for pre-install for payload {81B0CE07-2DA2-4c59-BA46-BC81E0656491}
          ::START TIMER:: [Pre payload :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}]
          In PrePayloadInstallProc
          Custom action return code: 1
          :: END TIMER :: [Pre payload :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}] took 4 miliseconds (0.004 seconds)
          [       0] Fri Nov 26 18:17:01 2010 ERROR
          Custom Action for payload {81B0CE07-2DA2-4c59-BA46-BC81E0656491} Common returned error. Failing this payload.
          Payload {651B14E1-BDA4-4AD2-B1D3-094FFE9AEA2D} can not be installed due to dependent operation failure.
          [       0] Fri Nov 26 18:17:01 2010  WARN
          Payload cannot be installed due to dependent operation failure
          Skipping payload {651B14E1-BDA4-4AD2-B1D3-094FFE9AEA2D} Common_LangPackCommonOther as payload is not cached
          Calling the custom action code for pre-install for payload {2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}
          ::START TIMER:: [Pre payload :{2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}]
          :: END TIMER :: [Pre payload :{2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}] took 11 miliseconds (0.011 seconds)
          Custom Action for payload {2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7} Presets returned error. Failing this payload.
          Payload {848B005A-4D0D-4A60-8F82-34F55781C65A} can not be installed due to dependent operation failure.
          Skipping payload {848B005A-4D0D-4A60-8F82-34F55781C65A} Presets_LangPackPresetsOther as payload is not cached
          Calling the custom action code for pre-install for payload {A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}
          ::START TIMER:: [Pre payload :{A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}]
          :: END TIMER :: [Pre payload :{A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}] took 4 miliseconds (0.004 seconds)
          Custom Action for payload {A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0} HD returned error. Failing this payload.
          Payload {59F0B800-D041-4120-A1B0-2EEBBF3FF79D} can not be installed due to dependent operation failure.
          Skipping payload {59F0B800-D041-4120-A1B0-2EEBBF3FF79D} HD_LangPackHDOther as payload is not cached
          Calling the custom action code for pre-install for payload {78C17FAA-2368-4505-BED6-C6F56F923AE0}
          ::START TIMER:: [Pre payload :{78C17FAA-2368-4505-BED6-C6F56F923AE0}]
          :: END TIMER :: [Pre payload :{78C17FAA-2368-4505-BED6-C6F56F923AE0}] took 10 miliseconds (0.01 seconds)
          Custom Action for payload {78C17FAA-2368-4505-BED6-C6F56F923AE0} SD returned error. Failing this payload.
          Payload {861E2110-16F6-4E67-87F0-AF11332A4599} can not be installed due to dependent operation failure.
          Skipping payload {861E2110-16F6-4E67-87F0-AF11332A4599} SD_LangPackSDOther as payload is not cached
          Calling the custom action code for pre-install for payload {A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}
          ::START TIMER:: [Pre payload :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}]
          :: END TIMER :: [Pre payload :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 3 miliseconds (0.003 seconds) DTR = 1333.33 KBPS (1.30208 MBPS)
          Custom Action for payload {A85C9905-3D8E-41FF-A031-15DB7EFFA6E5} PreMacContentInstaller returned error. Failing this payload.
          Payload {07CE3591-3679-4058-8552-44A2F23613B8} can not be installed due to dependent operation failure.
          Skipping payload {07CE3591-3679-4058-8552-44A2F23613B8} PreMacContentInstaller_LangPacken_US as payload is not cached
          [       0] Fri Nov 26 18:17:07 2010  INFO
          No operation.  We're done:
          Updating driver data - Action: Remove driver entry
          Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
          [       0] Fri Nov 26 18:17:09 2010  INFO
          Total components installed: 0
          Total components repaired: 0
          Total components removed: 0
          [       0] Fri Nov 26 18:17:09 2010 ERROR
          The following payload errors were found during install:
          - PreMacContentInstaller_LangPacken_US: Install failed
          - Presets: Failed due to Language Pack installation failure
          - HD_LangPackHDOther: Install failed
          - Common_LangPackCommonOther: Install failed
          - SD: Failed due to Language Pack installation failure
          - Common: Failed due to Language Pack installation failure
          - Presets_LangPackPresetsOther: Install failed
          - SD_LangPackSDOther: Install failed
          - HD: Failed due to Language Pack installation failure
          - PreMacContentInstaller: Failed due to Language Pack installation failure
          Call PostSession Custom Hook
          ::START TIMER:: [Post session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}]
          In InstallSessionCloseProc
          :: END TIMER :: [Post session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 0 miliseconds (0 seconds)
          :: END TIMER :: [Total Timer] took 22938 miliseconds (22.938 seconds) DTR = 75.6823 KBPS (0.0739085 MBPS)
          -------------------------------------- Summary --------------------------------------
          - 0 fatal error(s), 16 error(s), 5 warning(s)
          WARNING: Payload cannot be installed due to dependent operation failure
          ERROR: Custom Action for payload {81B0CE07-2DA2-4c59-BA46-BC81E0656491} Common returned error. Failing this payload.
          ERROR: Custom Action for payload {2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7} Presets returned error. Failing this payload.
          ERROR: Custom Action for payload {A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0} HD returned error. Failing this payload.
          ERROR: Custom Action for payload {78C17FAA-2368-4505-BED6-C6F56F923AE0} SD returned error. Failing this payload.
          ERROR: Custom Action for payload {A85C9905-3D8E-41FF-A031-15DB7EFFA6E5} PreMacContentInstaller returned error. Failing this payload.
          ERROR: The following payload errors were found during install:
          ERROR:  - PreMacContentInstaller_LangPacken_US: Install failed
          ERROR:  - Presets: Failed due to Language Pack installation failure
          ERROR:  - HD_LangPackHDOther: Install failed
          ERROR:  - Common_LangPackCommonOther: Install failed
          ERROR:  - SD: Failed due to Language Pack installation failure
          ERROR:  - Common: Failed due to Language Pack installation failure
          ERROR:  - Presets_LangPackPresetsOther: Install failed
          ERROR:  - SD_LangPackSDOther: Install failed
          ERROR:  - HD: Failed due to Language Pack installation failure
          ERROR:  - PreMacContentInstaller: Failed due to Language Pack installation failure
          Search the same string above to find when the error occured.
          Exit Code: 7 - Unable to complete Silent workflow
          END - Installer Session
          [       0] Fri Nov 26 18:21:03 2010  INFO
          OSX version: 10.6.5
          CHECK : Credentials
          :: END TIMER :: [Bootstrap] took 4495 miliseconds (4.495 seconds) DTR = 8.89878 KBPS (0.00869021 MBPS)
          Sync Media DB ...
          :: END TIMER :: [Sync Media DB] took 676 miliseconds (0.676 seconds) DTR = 5.91716 KBPS (0.00577848 MBPS)
          :: END TIMER :: [System check :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}] took 53 miliseconds (0.053 seconds)
          :: END TIMER :: [System check :{2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}] took 1 miliseconds (0.001 seconds)
          [       0] Fri Nov 26 18:21:04 2010  INFO
          :: END TIMER :: [System check :{78C17FAA-2368-4505-BED6-C6F56F923AE0}] took 9 miliseconds (0.009 seconds)
          :: END TIMER :: [System check :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 0 miliseconds (0 seconds) DTR = inf KBPS (inf MBPS)
          :: END TIMER :: [Pre session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 13 miliseconds (0.013 seconds)
          [       0] Fri Nov 26 18:21:04 2010 ERROR
          [       0] Fri Nov 26 18:21:04 2010  WARN
          :: END TIMER :: [Pre payload :{2B3B0E84-7724-48ed-BEA4-15F5ED8FBAD7}] took 4 miliseconds (0.004 seconds)
          :: END TIMER :: [Pre payload :{A29C9F23-87F1-4651-ADF7-2CB7CC7F79B0}] took 3 miliseconds (0.003 seconds)
          :: END TIMER :: [Pre payload :{78C17FAA-2368-4505-BED6-C6F56F923AE0}] took 3 miliseconds (0.003 seconds)
          [       0] Fri Nov 26 18:21:09 2010  INFO
          [       0] Fri Nov 26 18:21:11 2010  INFO
          [       0] Fri Nov 26 18:21:11 2010 ERROR
          :: END TIMER :: [Post session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 2 miliseconds (0.002 seconds)
          :: END TIMER :: [Total Timer] took 14661 miliseconds (14.661 seconds) DTR = 5.18382 KBPS (0.00506233 MBPS)
          OSX version: 10.6.5
          CHECK : Credentials
          :: END TIMER :: [Bootstrap] took 4144 miliseconds (4.144 seconds) DTR = 3.861 KBPS (0.00377051 MBPS)
          Sync Media DB ...
          :: END TIMER :: [Sync Media DB] took 338 miliseconds (0.338 seconds)
          :: END TIMER :: [System check :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}] took 12 miliseconds (0.012 seconds)
          [       0] Fri Nov 26 18:30:44 2010  INFO
          :: END TIMER :: [System check :{78C17FAA-2368-4505-BED6-C6F56F923AE0}] took 0 miliseconds (0 seconds)
          [       0] Fri Nov 26 18:30:45 2010  INFO
          :: END TIMER :: [System check :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 4 miliseconds (0.004 seconds)
          :: END TIMER :: [Pre session :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 0 miliseconds (0 seconds)
          :: END TIMER :: [Pre payload :{81B0CE07-2DA2-4c59-BA46-BC81E0656491}] took 3 miliseconds (0.003 seconds)
          [       0] Fri Nov 26 18:30:45 2010 ERROR
          [       0] Fri Nov 26 18:30:45 2010  WARN
          :: END TIMER :: [Pre payload :{78C17FAA-2368-4505-BED6-C6F56F923AE0}] took 4 miliseconds (0.004 seconds)
          :: END TIMER :: [Pre payload :{A85C9905-3D8E-41FF-A031-15DB7EFFA6E5}] took 4 miliseconds (0.004 seconds) DTR = 1000 KBPS (0.976562 MBPS)
          [       0] Fri Nov 26 18:30:50 2010  INFO
          [       0] Fri Nov 26 18:30:52 2010  INFO
          [       0] Fri Nov 26 18:30:52 2010 ERROR
          :: END TIMER :: [Total Timer] took 14402 miliseconds (14.402 seconds) DTR = 3.33287 KBPS (0.00325476 MBPS)
          Meantime Elements 9 seems to work, so will await advice or a new disc.
          I am on Mac 10.6.5, Processor 2.33 Ghz  DDR2  SDRAM
          Model Name: iMac
            Model Identifier: iMac5,1
            Processor Name: Intel Core 2 Duo
            Processor Speed: 2.33 GHz
            Number Of Processors: 1
            Total Number Of Cores: 2
            L2 Cache: 4 MB
            Memory: 2 GB
            Bus Speed: 667 MHz
            Boot ROM Version: IM51.0090.B09
            SMC Version (system): 1.9f4
            Serial Number (system): CK7230JJVUW
            Hardware UUID: 00000000-0000-1000-8000-0017F2DF3937
               Anyone ?    Or should I just forget it ?
               Eric
          • 2. Re: Installing Premiere 9 on MAC
            rx4tx
            New to this site and was directed here by Adobe when I tried to "contact" someone about a problem I am experiencing.  I am having this same problem.  Premiere Elements 9 disc won't install on my MAC similar to the people that have posted on here before me.  So their posts were months ago so am I to understand that this forum is for people to help each other or is Adobe actually monitoring and helping out?
            • 3. Re: Installing Premiere 9 on MAC
              Fredbloggsx2 Level 1
                        Hello.   After looking otpossible solutions and the purpose of "Premiere 9", I decided that I didn't really need it for anything I do, so abandoned the query and went back to doing my normal activity.
                        Sorry I can't help you further.
                    Fred
