3 Replies Latest reply on Oct 12, 2010 9:36 PM by BhaskerChari
    tile list reverse order
    Seglespaan Level 1
      Hey,
      anyone know if its possible to reverse the order of a tile list?
      say I have an array
      array
      item 1
      item 2
      item 3
      /array
      I want to display item 3 at the top of my list and 1 at the bottom?
      Cheers
      Tim
        • 1. Re: tile list reverse order
          BhaskerChari Level 4
          Hi Seglespaan,
          Just try to reverse the dataprovider Array for your TileList.
          myArray.reverse();
          Bhasker
          • 2. Re: tile list reverse order
            Seglespaan Level 1
            Sorry my bad,
            it's actually an arraycollection I've got,
            if i use the array collection as my dataprovider all is well (apart from the tiles being in the wrong order), however if I use either
            myArrayCollection.reverse()    or    myArrayCollection.source.reverse() as my data provider it doesn't load the tiles correctly.
            any ideas??
            • 3. Re: tile list reverse order
              Hi Seglespaan,
              I think  myArrayCollection.source.reverse(); should work for you..
              Check out this simple example below...
              <?xml version="1.0"?>
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                 initialize="initData();" >
                 <mx:Script>
                 <![CDATA[
                    import mx.controls.Button;
                    import mx.collections.*;
                    private var listArray:Array=[
                       {label: "item0", data: 0},{label: "item1", data: 1},
                       {label: "item2", data: 2},{label: "item3", data: 3},
                       {label: "item4", data: 4},{label: "item5", data: 5},
                       {label: "item6", data: 6},{label: "item7", data: 7},
                       {label: "item8", data: 8}];
                    [Bindable]
                    public var TileListdp:ArrayCollection;
                    private function initData():void {
                       TileListdp = new ArrayCollection(listArray);
                       TileListdp.source.reverse();
                 </mx:Script>
                 <mx:TileList dataProvider="{TileListdp}"
                    itemRenderer="mx.controls.Button"/>
              </mx:Application>
              Bhasker
