4 Replies Latest reply on Jul 24, 2013 7:45 PM by turbidity
    Flash builder plugin eclipse error
    citynong
      Can anybody help I am getting this error since I opened the eclipse
      message: Problems occurred when invoking code from plug-in: "org.eclipse.jface".
      exception stack trace:
      java.lang.NoClassDefFoundError: com/adobe/flexbuilder/codemodel/common/CMFactory
      at com.adobe.flexbuilder.as.editor.ui.actions.OpenTypeAction.selectionChanged(OpenTypeAction .java:107)
      at org.eclipse.ui.internal.PluginAction.refreshEnablement(PluginAction.java:206)
      at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:277)
      at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:299)
      at org.eclipse.ui.internal.AbstractSelectionService.fireSelection(AbstractSelectionService.j ava:156)
      at org.eclipse.ui.internal.AbstractSelectionService$1.selectionChanged(AbstractSelectionServ ice.java:62)
      at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
      at org.eclipse.core.runtime.Platform.run(Platform.java:888)
      at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
      at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
      at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:160)
      at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2132)
      at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1160)
      at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1190)
      at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:228)
      at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:222)
      at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:389)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3910)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3503)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
      at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      session data:
      eclipse.buildId=unknown
      java.version=1.6.0_13
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
      Framework arguments:  -product org.eclipse.epp.package.jee.product
      Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
        • 1. Re: Flash builder plugin eclipse error
          RyanFaith
          I received the same error, and I have reinstalled everything and still got the same error. I've run eclipse -clean as well. I've got JDK 1.5 and 1.6 installed on my computer.
          eclipse.buildId=M20100909-0800
          java.version=1.5.0_17
          BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
          Framework arguments:  -product org.eclipse.epp.package.java.product
          Command-line arguments:  -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
          Error
          Mon Feb 14 11:12:11 MST 2011
          Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
          at org.eclipse.ui.internal.AbstractSelectionService.setActivePart(AbstractSelectionService.j ava:291)
          at org.eclipse.ui.internal.WWinPartService.updateActivePart(WWinPartService.java:134)
          at org.eclipse.ui.internal.WWinPartService.access$0(WWinPartService.java:125)
          at org.eclipse.ui.internal.WWinPartService$WWinListener.partDeactivated(WWinPartService.java :50)
          at org.eclipse.ui.internal.PartListenerList2$4.run(PartListenerList2.java:115)
          at org.eclipse.ui.internal.PartListenerList2.fireEvent(PartListenerList2.java:55)
          at org.eclipse.ui.internal.PartListenerList2.firePartDeactivated(PartListenerList2.java:113)
          at org.eclipse.ui.internal.PartService.firePartDeactivated(PartService.java:242)
          at org.eclipse.ui.internal.PartService.setActivePart(PartService.java:300)
          at org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePartChanged(WorkbenchPagePartList .java:57)
          at org.eclipse.ui.internal.PartList.setActivePart(PartList.java:136)
          at org.eclipse.ui.internal.WorkbenchPage.setActivePart(WorkbenchPage.java:3537)
          at org.eclipse.ui.internal.WorkbenchPage.internalActivate(WorkbenchPage.java:617)
          at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage.java:589)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2875)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
          at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
          at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
          at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
          at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
          at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:365)
          at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:168)
          at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
          at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:208)
          at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.ja va:274)
          at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
          at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExpl orerActionGroup.java:373)
          at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.ja va:526)
          at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHel per.java:48)
          at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
          at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
          at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
          at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
          at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
          at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
          at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
          at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
          at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
          at java.lang.reflect.Method.invoke(Method.java:585)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
          • 2. Re: Flash builder plugin eclipse error
            MrShenuhan
            Hello,
            I had the same problem, and I manage to solve it !
            First we need to check if it is actually the same problem...
            When you enter the "plug in register" (or some name that is close I am in french so I roughly translated ) view in eclipse, look for the plugin called com.adobe.flashbuilder.codemodel. Is it started (green arrow) ?
            If not, it means it could not start. To know the reason, you need to see in Eclipse error log an exception that concerns this plugin. For me it was :
            Caused by: java.lang.ClassCastException: com.ctc.wstx.sr.ValidatingStreamReader incompatible with org.codehaus.stax2.XMLStreamReader2
            This exception is caused by the fact that adobe com.adobe.flash.codemodel.osgi use some third party package (com.ctc.wstx) by including it directly in it's package definition.You can find the given package in : %Adobe_install%\eclipse\plugins\com.adobe.flash.codemodel.osgi_%version%\classes. As they use it without giving any version number, if any other plugin in your eclipse declare the same third party library adobe might use this one... And in any previous to 4.0.0 version of com.ctc.wstx the ValidatingStreamReader inherite org.codehaus.stax2.XMLStreamReader and not org.codehaus.stax2.XMLStreamReader2.
            I have made a workaround by creating a plugin version of the adobe third party lib. I can help you through it if this is indeed your problem.
            Regards
            • 3. Re: Flash builder plugin eclipse error
              guinetik
              Well, i had this problem because my computer crashed with flash builder opened.
              i reinstallled and the problem continued so i had an idea that this could be some workspace related ****. so i removed the workspace (ie: delete the metadata flder inside of your workspace) and recreated it.
              works ok now
              • 4. Re: Flash builder plugin eclipse error
                turbidity Level 1
                Guinetik, thanks for the advice. I deleted the old workspace and created a new one and the CMFactory problem went away.
