4 Replies Latest reply on Oct 12, 2010 9:41 AM by Flex harUI
    Convert HEX string to double (using ByteArray?)
    FrankDelporte
      Hello,
      I have a HEX string I whish to convert back to a double number.
      The hex code comes from a C# program which processes data like this:
      byte[] bytes = BitConverter.GetBytes(val);
      where val is a double.
      So for example the number 3985856 is converted to 00 00 00 00 E0 68 4E 41.
      Starting from the hex value as a string, how could this be converted back to a number with actionscript ?
      This is my code but gives an error #2030: end of file was encountered.
      var str:String = "00000000E0684E41";
      public static function hex2double(str:String):Number
        var rt:Number = 0;
        var b:ByteArray = new ByteArray();
        for (var i:Number = 0; i < str.length / 2; i++)
           var thisNumber:int = parseInt(str.substr(i * 2, 2), 16);
           b.writeByte(thisNumber);
        try
           rt = b.readDouble();
        catch(e:EOFError)
           trace(e);
        return rt;
      Frank
