9 Replies Latest reply on Oct 15, 2010 10:42 AM by Flex harUI
    Datagrid filters and summary
    jfb00 Level 3
      Hi all,
      I found this component for filters in datagrids
      http://www.iwobanas.com/2009/07/creating-mdatagrid-date-filter/comment-page-1/#comments
      I want to have also a column summary in my datagrid.
      Does anyone know any component up there?
      Or maybe I can add that funtionality to this component. Maybe someone can guide me on that.
      Johnny
        • 1. Re: Datagrid filters and summary
          jfb00 Level 3
          Anyone??? Any ideas???
          Nobody knows about custom components.
          Johnny
          • 2. Re: Datagrid filters and summary
            Flex harUI Adobe Employee
            Do you want something like the DataGrid Footer example on my blog?
            Alex Harui
            Flex SDK Team
            Adobe System, Inc.
            http://blogs.adobe.com/aharui
            • 3. Re: Datagrid filters and summary
              jfb00 Level 3
              Yes, but I want to combine that with filters in the datagrid.
              The filter component that I found use ISearchable class, I went thru the component and it doesn't have the structure of a regular component.
              Do you have anything to learn hwo to do custom components?
              It's a place to get training for that?
              Johnny
              • 4. Re: Datagrid filters and summary
                jfb00 Level 3
                Hi Alex,
                I did something to put both component to work. In my app I got an error:
                1172: Definition com.iwobanas.controls.dataGridClasses.filterEditors:MultipleChoiceFilterEditor_inlineComp onent1 could not be found.
                1202: Access of undefined property MultipleChoiceFilterEditor_inlineComponent1 in package com.iwobanas.controls.dataGridClasses.filterEditors.
                The error point to mx component in this part:
                <mx:List id="labelList" dataProvider="{filter.labels}" width="100%"  backgroundColor="white">
                        <mx:itemRenderer>
                            <mx:Component>
                                <mx:CheckBox label="{data}"
                                             selected="{parentDocument.filter.selectedLabels.contains(data)}"
                                             change="{selected ? parentDocument.filter.selectLabel(data):parentDocument.filter.deselectLabel(data)}">
                                </mx:CheckBox>
                            </mx:Component>
                        </mx:itemRenderer>
                    </mx:List>
                when I use both in a separate app works fine. Any ideas?
                I have a test application to share.
                Johnny
                • 5. Re: Datagrid filters and summary
                  Sounds like the SWC isn't in your library path
                  • 6. Re: Datagrid filters and summary
                    jfb00 Level 3
                    I don't use SWC file, All for this two custom components are in my COM folder. It's a way to sent you my test sample?
                    Well if you have some couple minutes to take a look
                    In my test app it works fine, I have the same code in my app and it shows this error only if i call the filter otherwise it doesn't show.
                    In my canvas component at the top I declare the custom component as:
                    xmlns:dgFooter="com.forestandthetrees.controls.dgFooter.*"
                    But at the time of typing it shows dgFooter and dgFooter1 ( this one pointing to another custom component that only does the summary but not filters).
                    Any other ideas?
                    Thanks!
                    Johnny
                    • 7. Re: Datagrid filters and summary
                      Is the Canvas in a sub-folder such that the path
                      com.forestandthetrees.controls.dgFooter isn't valid?
                      • 8. Re: Datagrid filters and summary
                        jfb00 Level 3
                        My component is in my src root folder.
                        The component is in my subfolder com.forestandthetrees.controls.dgFoote.
                        Like I said it works in my test app.
                        Any other ideas?
                        • 9. Re: Datagrid filters and summary
                          You may need to import the com.iwobanas class.
