2 Replies Latest reply on Oct 12, 2010 9:04 AM by Todd_Kopriva
    is 4gb of RAM would be enough for AE CS5?
    richi_power
      Hi  guys, I have a problem that bothers me sometime. I have 4gb of RAM  running 64bit windows 7 and I use a lot of heavy programs like after  effects, 3ds max, CAD, photoshop, etc. Is 4gb enough for my computer or  should I increase my RAM? Please somebody help me, any suggestion would  be appreciated. Thank you
        • 1. Re: is 4gb of RAM would be enough for AE CS5?
          Yes, it is "enough" to run AE, but whether it will be enjoyable working, is another matter. You definitely should at least double the amount of RAM if you can afford it or go even higher within what your motherboard supports and your purse allows for...
          Mylenium
          • 2. Re: is 4gb of RAM would be enough for AE CS5?
            Todd_Kopriva Level 8
            4GB is enough to run After Effects, but it's far from the optimum amount. It's an especially low amount if you'll be running any other programs at the same time.
            It depends on what kind of work you're doing. Let's say that you'll be working with HD video and maybe 2K film. In that case, you'd ideally have 3GB installed per processor core. So, if you have a four-coure computer (which has eight processor cores with hyperthreading), you'd have 24GB of RAM. That's exactly how my home computer is set up. If you're working with 4K film, you'd have more RAM; for SD TV, you could have less.
            See this page for some information about memory settings and performance:
            http://forums.adobe.com/thread/543440
