12 Replies Latest reply on Sep 5, 2016 10:05 AM by drerol74
    Delete xml element not used in document
    Mikael Bossel
      If you have a number of texts tagged with an xml element and then delete the text, the element still exist in the structure.
      You can see the element still connected to a text, by the blue diamond on the element symbol.
      But i want do delete the elements that have no connection to texts, but cant find the right property to look for.
      In Java script CS4.
      Anyone knows?
      /Mikael
        • 1. Re: Delete xml element not used in document
          I'm having troubles getting the blue diamond (Strange -- I seem to have no problem with that at work!)
          But: perhaps you can test xmlItems[xxx].characters.length -- if it's zero, there are no characters connected. You should still check if it might have children, though, because it might be possible these still point to text.
          (.. Thinking, while typing that last sentence: or maybe they don't .. logically, the 'parent' also points to each item 'in' it.)
          • 2. Re: Delete xml element not used in document
            Mikael Bossel Level 1
            Nope,
            If you create a new document with two textframes, tag them "myTag", then delete one of the text frames, and run this:
            var myTag  = app.activeDocument.xmlElements[0];
            $.write(myTag.characters.length, myTag.contents);
            You still get the characters and contents out. The same goes for paragraph, texts.
            I just cant find the difference between the tag with content on the page or the one without...
            /Mikael
            • 3. Re: Delete xml element not used in document
              JohnDevlon Level 1
              Does anyone found a solution for this problem?
              I have the same problem. I can't find out how to detect if the XML element is attached to a object on the page or not. It's a mistery ... Maybe future generations will remember this problem as the one problem that couldn't be solved ...
              John
              • 4. Re: Delete xml element not used in document
                Loic.Aigon Adobe Community Professional
                Here is an absurd way :
                var doc = app.activeDocument;
                var root=doc.xmlElements[0];
                var n1 = root.xmlElements[0];
                app.select(n1.parentStory.characters[0]); //Crashes Indesign if n1 is not placed in the document
                But it doesn't help that much sorry. Looking further...
                Loic
                • 5. Re: Delete xml element not used in document
                  Maybe this way :
                  var n2= root.xmlElements[1];
                  try{
                      n1.insertionPoints[0].parent.texts[0].parentTextFrames[0].constructor;
                      alert("It's on the document !");
                  catch(e){
                      alert("No, it isn't !");
                  If a node is placed on the document you get access to the parent text frame. On the contrary, this call will fail if the node isn't placed.
                  Loic
                  • 6. Re: Delete xml element not used in document
                    Rob PBW Level 1
                    I heard this works but haven't tried myself:
                    app.activeDocument.deleteUnusedTags()
                    • 7. Re: Delete xml element not used in document
                      Thanks Rob,
                      It do exactly what you expect, it deletes Unused Tags (From the tag list)
                      But Unused XML Elements, still there, and still bugging me.
                      /Mikael
                      • 8. Re: Delete xml element not used in document
                        absqua Level 4
                        If the (text) element is unplaced, its parentStory will be an XmlStory rather than a Story.
                        So try:
                        var elements = app.activeDocument.xmlElements[0].xmlElements.everyItem().getElements();
                        for (var i = elements.length - 1;i >= 0;i--){
                            if(elements[i].parentStory.constructor.name === "XmlStory"){
                                elements[i].remove();
                        This is untested. If you have tagged graphics frames it will need to be modified to not error on those.
                        Jeff
                        • 9. Re: Delete xml element not used in document
                          marcob88041213
                          Does anyone solved this problem?
                          • 10. Re: Delete xml element not used in document
                            drerol74 Level 2
                            Hmmm, a little bit late for an answer, but this works for me. If someone would like to test it ...
                            var _xmlElement = app.activeDocument.xmlElements[0];
                            var _xmlPlaced = __isXMLElementPlaced(_xmlElement);
                            switch(_xmlPlaced) {
                                case true :
                                    alert(_xmlElement.markupTag.name + " (or one of the children) placed");
                                    break;
                                case false :
                                    alert(_xmlElement.markupTag.name + " not placed");
                                    break;
                                default :
                                    alert("No valid XML Element.");
                            function __isXMLElementPlaced(_xmlElement) {
                                if(!_xmlElement ||  !_xmlElement.isValid || !(_xmlElement instanceof XMLElement)) {
                                    return null;
                                var _xmlChildren;
                                var _numOfXMLChildren;
                                var _xmlChildPlaced;
                                var i;
                                if(_xmlElement.parentStory instanceof XmlStory && _xmlElement.xmlContent instanceof Text) {
                                    _xmlChildren = _xmlElement.xmlElements.everyItem().getElements();
                                    _numOfXMLChildren = _xmlChildren.length;
                                    for(i=0; i<_numOfXMLChildren; i++) {
                                        _xmlChildPlaced = __isXMLElementPlaced(_xmlChildren[i]);
                                        if(_xmlChildPlaced === true) {
                                            return true;
                                    return false;
                                } else {
                                    return true;
                            } /* END function __isXMLElementPlaced */
                            Roland
                            • 11. Re: Delete xml element not used in document
                              Try this:
                              var main = function() {
                                var doc = app.properties.activeDocument,
                                xes, xe;
                                if (!doc) return;
                                xes = doc.xmlElements[0].evaluateXPathExpression(".//*");
                                while ( xe = xes.pop() ) {
                                xe.texts[0].isValid && !xe.texts[0].parentTextFrames.length && xe.remove();
                              var u;
                              app.doScript("main();",u,u,UndoModes.ENTIRE_SCRIPT);
                              • 12. Re: Delete xml element not used in document
                                drerol74 Level 2
                                Hi Loic,
                                good idea with texts[0]. It works.
                                The reason why I ended up using a recursive function instead of xpath: some of the elements in my document are not placed, but have placed children.
                                Roland
