0 Replies Latest reply on Oct 12, 2010 3:50 PM by brcbuzz
    RoboHelp_CSH.RH_ShowLocalHelp opens two IE Windows
    brcbuzz
      Thanks for reading my post.  I have a question regarding calling "RH_ShowLocalHelp" from a Windows forms .NET application written in Visual Basic using .net framework 3.5
      When the source code below is called in our application it opens two IE 8 windows. One window loads the main help entry page and the other IE window is blank with the string "Connecting..." in the tab.  Here is the call...
      Helper.RH_ShowLocalHelp(
      "", helpLocation, paramType, paramValue)
      The page that loads the help entry page displays the security bar stating that 'IE has restricted this webpage from running scripts or ActiveX controls..."  I have tried to change the options to allow scripts, etc but nothing seems to work.
      Is it IE security that is opening the other IE window with the "Connecting..." string in the tab?  Anyway, any help to solve this issue would be greatly appreciated. Below is the full source of code.
      Dim Helper As RoboHelpAPI.RoboHelp_CSH = New RoboHelpAPI.RoboHelp_CSH
      Dim Mapper As HelpMap = New HelpMap
      Dim paramType As Integer = RoboHelpAPI.RoboHelp_CSH.CSH_DISPLAY_CONTEXT
      Dim appPath As String = Application.StartupPath()
      Dim helpURL As String = "Help\WebHelp\DeT_Help.htm"
      Dim paramValue As Integer
      If (Debugger.IsAttached()) Then
      appPath = appPath.Replace(
      "bin", "")
      End If
      Dim helpLocation As String = appPath & helpURL
      Dim fm As Form = Me.ActiveMdiChild
      If fm Is Nothing Then
      paramValue = 302
      Else
      paramValue = Mapper.GetHelpMap(fm.Name)
      End If
