2 Replies Latest reply on Jul 19, 2007 11:31 AM by Flex_Architect
    Possible Bug (Flex2 and Flex3)
    Flex_Architect
      I am having a repeatable problem with both Flex 2 and 3 when using a sorted DataGrid.
      When doing the following sequence an error occurs:
      1) Fill a DataGrid with object data
      2) User sorts the grid using header click
      3) User or system adds a new object to the grid and in the same process system sets the DataGrid's selectedItem property to the newly added
      4) An error is produced when referencing the selectedItem
      When investigating this issue, it appears that the selectedItem property is set to null, although the selectedIndex value does have a number. The grid "looks" fine (i.e. it has the row highlighted correctly)... but there is nothing in selectedItem.
      This only seems to happen when adding, immediately selecting (with code) a new object when the grid is currently sorted. Also, a user generated event (i.e. click) WILL select the row just fine.
      As of now, the only way around this problem seems to be to remove the sort before adding and selecting the item, and then putting it back in (a real pain in the neck in a large application).
      Please see the attached code for an example of this.
