4 Replies Latest reply on Oct 14, 2010 10:54 AM by Ijimero
    RichTextEditor fontsize issue
    Ijimero
      I'm trying to use RichTextEditor, but the fontsize of the htmlText don't change, and is always a big size font... it change on the component, but when i check on HTML it remains big.
      I have no idea how to fix that problem...
      can anybody help me?
        • 1. Re: RichTextEditor fontsize issue
          Flex harUI Adobe Employee
          Any font tags in the HTML will override what you set on the component.
          • 2. Re: RichTextEditor fontsize issue
            Ijimero Level 1
            I managed to identify the problem...
            the problem is that the component uses the "SIZE" (that are predetermined sizes that goes from 1 to 7), where it should be using the fontsize, wich is a style, that's why it never changes the size of the font, it because the value is always is above 7...
            <TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Verdana" SIZE="14" COLOR="#0B333C" LETTERSPACING="0" KERNING="0">.</FONT></P></TEXTFORMAT>
            how can this be corrected?
            • 3. Re: RichTextEditor fontsize issue
              The component or the html?  If it is the html, you'll have to modify the
              html.
              • 4. Re: RichTextEditor fontsize issue
                Ijimero Level 1
                well, after some research i've managed to change the html..
                i've created the following function:
                          private function fixHtmlSize(str:String):String{
                               //str = RichTextEditor.htmlText
                                var pattern:RegExp = /SIZE=\"(.*?)\"/g;
                                return (str.replace(pattern, 'style="font-size:$1px;"'));
                that solved the problem.
