2 Replies Latest reply on Jul 20, 2007 6:34 PM by Opera Rat
    Splash screen for Mac
    Opera Rat
      If I use a .PICT with the same name and in the same directory as my projector will it work as a Splash screeen? I did it with a .PCT file and that worked. Are these the same file type?
        • 1. Re: Splash screen for Mac
          Level 7
          I believe they are the same format. Typically .PCT would be the file
          extension used on Windows to comply with the old 8.3 DOS naming convention.
          I don't work on Macs, but my guess is it should work. If it doesn't then you
          could probably just change the extension to .PCT.
          "Opera Rat" <webforumsuser@macromedia.com> wrote in message
          news:f7mh67$5bl$1@forums.macromedia.com...
          • 2. Re: Splash screen for Mac
            Opera Rat Level 1
            Nope. It didn't work. I was able to convert the original BMP to a PCT, now I have to travel one hour to get to the closest Mac and test it. It should work because I did it with a PCT before successfully.
