2 Replies Latest reply on Oct 15, 2010 5:48 AM by pguerett
    Tab Order works in Acrobat, but not Reader?
    Diane_234
      Using LiveCycle 8.0, I set the tab order in this fiscal chart so the order would flow in the direction of the arrows depicted in the chart below. Saved the LiveCycle doc; then I opened it in AcrobatPro 8.0 and enabled Reader usage rights. Saved file. It tested fine and tabbed in the order that I wanted. However......see second screen shot:
      When I tested the form in Reader 9.0, the tab order is not in the sequence that I set it up in LiveCycle. Now it tabs horizontally, then down to the next row. I need it to tab each column vertically (See screen shot above). Did I miss a step somewhere?
      Click here for the form.
