5 Replies Latest reply on Dec 13, 2010 1:59 PM by Pyramid Pyro
    Problem with Cross Dissolve and Opacity
    bbuie1
      I've been noticing that Cross Dissolve has been acting goofey for awhile but have overcome any problems by manually adjusting opacity settings.  However, this time I can't get either to cooperate. Notice the line appearing below the phrase "the nutrient recommendation map" in the image below.  This line or a similar line will appear as title either cross dissolve into one another or if they are stand alone and the opacity settings fade them in and out.  The blinking of the lines is sporadic and changes as I make adjustments.  I'll "fix" one spot but they will start to blink at other points in the time line and in different areas.
      Any ideas?
