3 Replies Latest reply on Oct 13, 2010 10:45 PM by TheCronzy
    Ram Preview
    TheCronzy
      Hello,
      Has anyone had a problem ram previewing image sequences in CS5?
      I have a targa sequence, all is fine (frame rate, size etc) but when I
      press space bar there is a pause then Premiere attempts to play it
      real time (choppy) rather than generate a ram preview. Also the ram bar in the
      timeline remains red and doesn't turn green while playing.
      I've set all of my media and cache to c:/temp so I don't think it
      is a permission problem. Creating full previews [ENTER] works
      fine.
      Is there a setting that I am missing? I've never seen this before.
      Cheers
      rC
        • 1. Re: Ram Preview
          Andy Urtu Level 1
          do you have more than 1 hardisk?  As Haarm would say, you need at least 3 drives.  C: for system, Video drive, and a Scratch drive.
          • 2. Re: Ram Preview
            Harm Millaard Level 7
            This is PR, not AE where you have RAM previews. PR does not have RAM previews.
            If the timeline bar is red, it indicates that for fluid preview (not choppy) you need to render it first by pressing Enter. If you skip that step and just press the spacebar, no preview files will be created and the preview is likely to be choppy.
            Putting you media cache on the C drive is not a good approach. It will require a lot of disk accesses from one and the same drive (Windows housekeeping, program, DLL's, pagefile, media cache, log files, etc.) and the limitation of all disks is that the head can only be in one place at a time, so it will be significantly slower and cause much more wear and tear than using multiple disks to spread the load. Hence the general suggestion to use at least three different physical 7200 SATA disks.
            • 3. Re: Ram Preview
              TheCronzy Level 1
              Oops you're right, I got my apps mixed up. I think it was the pause
              and choppiness that messed me up.
              Thanks for the drive suggestion,
              I'll try it out. rC
