12 Replies Latest reply on Oct 14, 2010 6:40 AM by Claudiu Ursica
    Pass a parameter to custom component -  get null
    Astraport2012 Level 1
      Main MXML (part of code):
      <s:Application
      xmlns:ns1="*"
      creationComplete="init();>
      import MyComponent;
      private function init():void {
      var myArray:Array=["FFF","TTT","RRR"];
      myComp.width=200;
      myComp.height=200;
      myComp.getArray = myArray;
      myContainer.rawChildren.addChild(myComp);
      <fx:Declarations>
      <ns1:MyComponent id="myComp" x="0" y="0" />
      </fx:Declarations>
      custom component:
      package
                public var getArray:Array;
      public class MyComponent extends Sprite { trace (getArray);//trace null
        • 1. Re: Pass a parameter to custom component -  get null
          Gregory Lafrance Level 6
          I would not declare MyComponent in MXML, but in ActionScript in the script block.
          I believe the AS is executed first, so unless you have setup AS in MyComponent creationComplete event handler, when the AS you have is executed, MyComponent does not yet exist.
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex Training and Support Services
          • 2. Re: Pass a parameter to custom component -  get null
            Thank you.
            I know this, but need to solve the problem this way.
            • 3. Re: Pass a parameter to custom component -  get null
              Claudiu Ursica-USyc3k Level 1
              What is myContainer?
              I have a working version with my container as UICOmponent inside main.
              public class MyComp extends Sprite
                      private var _getArray:Array;
                      public function MyComp()
                      public function get getArray():Array
                          return _getArray;
                      public function set getArray(value:Array):void
                          trace("setter ", value);
                          _getArray = value;
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             xmlns:ns1="*"
                             minWidth="955" minHeight="600"
                             creationComplete="init();">
                  <fx:Script>
                      <![CDATA[
                              myComp.width=200;
                              myComp.height=200;
                              myContainer.addChild(myComp);
                  </fx:Script>
                  <fx:Declarations>
                      <ns1:MyComp id="myComp"/>
                  </fx:Declarations>
                  <mx:UIComponent id="myContainer"/>
              </s:Application>
              Not sure this is what you after though but it traces:
              setter  FFF,TTT,RRR
              Why do you add to rawChildren?
              C
              • 4. Re: Pass a parameter to custom component -  get null
                OK. Then how I can create a custom component in the script block that I can send and receive variables?
                • 5. Re: Pass a parameter to custom component -  get null
                  Because I need to put my components in a container:
                  <mx:Container x="34" y="163" width="260" height="260" id="cloudContainer" borderStyle="solid" backgroundAlpha="0.0" borderColor="#91EED9" visible="true">
                  </mx:Container>
                  Thank you Claudiu
                  • 6. Re: Pass a parameter to custom component -  get null
                    Claudiu Ursica Level 4
                    cloudContainer.rawChildren.addChild(myComp);
                    replaced the old line with this and works...
                    C
                    • 7. Re: Pass a parameter to custom component -  get null
                      Hooray! Everything works fine! You are a genius:)
                      • 8. Re: Pass a parameter to custom component -  get null
                        I knew it. It does not matter. Thanks for the tip with getters and setters.
                        • 9. Re: Pass a parameter to custom component -  get null
                          JeffryHouser Level 4
                          I didn't see anyone say this yet, so..
                          Why are you defining the variable in the package, as opposed to the component:
                          Don't do this:
                          package
                          I'm surprised that even works.
                          Do this:
                          package
                          Which defines the variable in the body of the component. I'll also add that the trace statement is not in a method or constructor.  I had no idea that was possible either.  So, something more like this:
                          package
                          public function MyComponent():void{
                          In this situation, with the trace in the constructor, I would expect it to return null because no value is set for the Array yet.  To give more details, we'd have to see your where you actually perform the trace.
                          All that said, your code is horribly odd.  Why areyou trying to instantiate the component in the declarations section; then add it as a child on creationComplete?
                          • 10. Re: Pass a parameter to custom component -  get null
                            "All that said, your code is horribly odd."
                            I'd say so, I just took the code as it came tried to work with client's
                            material. I learned this the hard way, but I am trying to keep myself from
                            putting refactoring ideas all the time into peoples head.
                            Maybe they have a reason for writing the code like that.
                            C
                            • 11. Re: Pass a parameter to custom component -  get null
                              I do not remember, but only this method gave a positive result.
                              I tried for several hours. Component rather complicated - I gave a piece of code.
                              • 12. Re: Pass a parameter to custom component -  get null
                                It is better to overrid the createChildren() if you want to add children outside
                                MXML. I don't know your use case so I can't say what I have used instead of that
                                Sprite and the Wrapping container in that way.
                                C
                                To: Ursica Claudiu <the_braniak@yahoo.com>
                                Sent: Thu, October 14, 2010 3:21:00 PM
                                Subject: Re: Pass a parameter to custom component - get null
                                code.
