3 Replies Latest reply on Oct 15, 2010 1:21 PM by sanggpark
    Flex Unit failing to handle Async events
    sanggpark
      I have following class
      package
           import flash.events.Event;
           import flash.events.EventDispatcher;
           import mx.binding.utils.ChangeWatcher;
           public class TestPresentationModel extends EventDispatcher
                private var _index:int = 0;
                [Bindable(event="indexChanged")]
                public function set index(value:int):void
                     if (_index != value) {
                          _index = value;
                          dispatchEvent(new Event("indexChanged"));
                public function get index():int
                     return _index;
                public function TestPresentationModel()
                     ChangeWatcher.watch(this, "index", function(event:*):void {
                          if (index == 1) {
                               dispatchEvent(new Event("indexOne"));
      and following test case
      [Test(async)]
      public function testIndex():void
           var pm:TestPresentationModel = new TestPresentationModel();
           pm.index = 0;
           Async.failOnEvent(this, pm, "indexOne");
           Async.handleEvent(this, pm, "RandomEvent", handleRandomEvent);
           pm.index = 2;
      private function handleRandomEvent(event:Event, data:Object):void
           Assert.fail();
      For some reason this test is passing. "RandomEvent" never got fired so Async.handleEvent should've timeout. Even if "RandomEvent" was fired, it should've failed with Assret.fail(); However it's passing.... why is this?
        • 1. Re: Flex Unit failing to handle Async events
          sanggpark Level 1
          I changed the ChangeWatcher to
          if (index == 1) {
          } else if (index == 2) {
          dispatchEvent(new Event("RandomEvent"));
          which got me "Error: Asynchronous Event Received out of Order"
          This seems wrong as well. This sounds like to me Async was first expecting "indexOne" event then "RandomEvent" which makes me feel like once I have Async.failOnEvent(), I can have any more Async handlers afterwards.
          • 2. Re: Flex Unit failing to handle Async events
            mlabriola Level 4
            I will get you more info on this later to explain why, however:
            Change your code to look like this:
            Async.registerFailureEvent( this, pm, "indexOne" );
            //Async.failOnEvent(this, pm, "indexOne");
            This is what you are actually after... promise more details when I have time to type, just wanted to get you an answer fast.
            Mike
            • 3. Re: Flex Unit failing to handle Async events
              sanggpark Level 1
              Should I be using Async.registerFailureEvent for all of them? or just in the cases like this one?
