1 Reply Latest reply on Oct 14, 2010 2:09 PM by Devtron
    CDATA error
    miquael Level 1
      In Flash Builder, I'm getting this problem:
      "invalid character or markup found in script block.  Try surrounding your code with a CDATA block".
      Tho in fact, my code is already surrounded with a CDATA block, and the syntax is correct. What is the problem here?
                        xmlns:mx="library://ns.adobe.com/flex/mx"
                        implements="com.rfm.interfaces.IExercise"
                        xmlns:assets="com.rfm.assets.*"
                        xmlns:tapat="com.bpi.tapat.*"
                        width="800" height="600">
           <fx:Script>
           <![CDATA[
                import TPController;
                import TPModel;
                import TPViewer;
                import com.rfm.assets.AssetContainerMgr;
                import com.rfm.events.ExerciseEvent;
                import com.rfm.interfaces.IExercise;
                import com.rfm.state.GameState;
                import com.rfm.state.TaskModel;
                import com.rfm.test.TestInterface;
                import flash.events.*;
                import mx.controls.Alert;
                import mx.core.UIComponent;
                private var _spec:Object;
                public var startupAssets:Array = ['tapat_assets', 'global_assets'];
                public function startup(spec:Object, previousstate:Object):Boolean {
                     GameState.fromJSON(previousstate);
                     TestInterface.instance.register_object(this, 'currentExercise');
                     _spec = spec as TaskModel;
                     ldrview.load(startupAssets);
                     return true;
                public function kill():Boolean{
                     return true;
                public function status():Object{
                     return GameState.toJSON();
                public function pause():void{trace("pause");}
                public function resume():void{trace("resume");}
                public function easyConfig():void{trace("easyConfig");}
                public function mediumConfig():void{trace("mediumConfig");}
                public function hardConfig():void{trace("hardConfig");}
                public function easyStimulus():void{trace("easyStimulus");}
                public function mediumStimulus():void{trace("mediumStimulus");}
                public function hardStimulus():void{trace("hardStimulus");}
                public function prePrompt():void{
                     currentState = 'stimulus';
                     init();
                public function prompt(e):void{
                     GameState.write('did_tut', true);
                     currentState = 'prompt';
                public function nextTrial():void{
                public function trialComplete(correct:Boolean):void{
                     AssetContainerMgr.playMP3(correct?'ding':'thump')
                     prompt();
                private function finished():void{
                     dispatchEvent(new ExerciseEvent(ExerciseEvent.FINISHED, {}))
                private function problem():void{
                     dispatchEvent(new ExerciseEvent(ExerciseEvent.ERROR, {message: 'happy fun error'}))
                private function init():void{
                     var container:UIComponent = new UIComponent;
                     var TPM:TPModel = new TPModel();
                     var TPV:TPViewer = new TPViewer();
                     var TPC:TPController = new TPController();
           </fx:Script>
           <s:states>
                <s:State name="loading"/>
                <s:State name="prompt"/>
                <s:State name="stimulus"/>
           </s:states>
           <assets:AssetLoaderUI id="ldrview" done="prePrompt()" includeIn="loading"/>
           <tapat:TAPATSkin id="bg" excludeFrom="loading"/>
           <fx:Declarations>
                <tapat:colorfilters id="colorfilters"/>
           </fx:Declarations>
           <s:Button label="skip" click="finished()" skinClass="com.rfm.skins.TxtBtn"/>
      </s:Application>
        • 1. Re: CDATA error
          Devtron Level 3
          You have a bracket missing or a bad character somewhere. Im not going to dig it out for you.
          I would suggest removing all the code and pasting it back in, piece by piece. That will help you figure out where the bad syntax/character is.
          I noticed this too:
          ^ not sure if you need a semicolon at the end there???
