5 Replies Latest reply on Oct 15, 2010 9:12 PM by raphi-sz
    How to insert text in a mx:TextArea
    raphi-sz
      with a spark:TextArea, we have the useful method insertText at the cursor current position.
      But in my case, I must use a mx:RichTextEditor (because there isnt such a component in spark) which uses a mx:TextArea.
      But the mx:TextArea doesnt have the insertText method.
      I need this because I want to drag'n'drop a String from a Tree into the TextArea at the cursor current position.
      How can I do that?
      Thanks!
        • 1. Re: How to insert text in a mx:TextArea
          Flex harUI Adobe Employee
          You can subclass, access the internal TextField and call replaceText
          • 2. Re: How to insert text in a mx:TextArea
            raphi-sz Level 1
            Thanks for the answer.
            I try this but now I've got a new problem:
            I changed the mx:TextArea by a MyTextArea that extends the mx:TextArea and added a getter for TextField.
            But now, it seems that the html or text property is no longer mapped.
                 public class MyTextArea extends TextArea
                      public function MyTextArea()
                           super();
                           this.textField = new UITextField; // because the textField attribute is not accessible
                      public function getTextField():IUITextField
                           return textField;
            And the component:
            <mx:RichTextEditor id="richEditor"
                              htmlText="{repeatEditor.currentItem[1]}"  << This no longer works
                         initialize="initTextEditor(repeatEditor.currentIndex)"/>
            I set the textArea in the initTextEditor function.
            Why this no longer load the data from {repeatEditor.currentItem[1]} in the htmlText?
            • 3. Re: How to insert text in a mx:TextArea
              There should be no need to create a new UITextField.
              • 4. Re: How to insert text in a mx:TextArea
                raphi-sz Level 1
                I know, but when there is the initialisation of the RichTextEditor, it throw an error (in the RichTextEditor class) because the method getTextField returns null.
                Any idea?
                • 5. Re: How to insert text in a mx:TextArea
                  raphi-sz Level 1
                  I found finally a simplier solution:
                  to access textField property, use that:
                  textArea.mx_internal::getTextField().replaceText...
                  Thanks !
