1 Reply Latest reply on Oct 15, 2010 2:07 AM by Claudiu Ursica
    Passing data / calling function from child to parent window
    Yue_Hong Level 1
      how to pass data / call for a function from child native window to parent window in Adobe Air?
      Thanks.
        • 1. Re: Passing data / calling function from child to parent window
          Claudiu Ursica Level 4
          <s:WindowedApplication
              xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx">
              <fx:Declarations>
                  <!-- Place non-visual elements (e.g., services, value objects) here -->
              </fx:Declarations>
              <fx:Script>
                  <![CDATA[
                      private var winRef:MyWIn = new MyWIn();
                      private function openWindow():void
                          winRef.addEventListener("fromNewWindow", onWinEvent);
                          winRef.open();
                      private function onWinEvent(event:Event):void
                          trace("from window");
                          winRef.callFromParentTest();
              </fx:Script>
              <s:Button
                  label="Create Window"
                  click="openWindow()"/>
          </s:WindowedApplication>
          MyWIn
          <components:Window
              xmlns:components="spark.components.*"
              width="400"
              height="300">
              <fx:Script>
                  <![CDATA[
                      protected function btn_clickHandler(event:MouseEvent):void
                          dispatchEvent(new Event("fromNewWindow"));
                      public function callFromParentTest():void
                          trace("called from parent");
              </fx:Script>
              <fx:Declarations>
              </fx:Declarations>
              <s:Button id="btn" click="btn_clickHandler(event)" />
          </components:Window>
          This is handling back and forth cammunication like main app call method on the
          child window in this case as a result of the child window event dispatching. Not
          sure it is what you are after, not sure the best solution yet, I just started
          digging a little bit more into the air's apis.
          C
