0 Replies Latest reply on Jul 17, 2007 7:22 AM by TaylorJumbo
    Help with delivering dynamic text through an external file, through XML?
    TaylorJumbo
      I'm struggling to find the best way to deliver dynamic text from an external file, through XML, to a Flash file.
      I use small Flash pieces to deliver multiple sets of content through a single .swf file. An example is here: http://www.esi-intl.com/public/government/federal.asp
      In the .swf file at the bottom, I'm using a three-scene .fla file. I'm putting the actionScript in the Actions layer atop each frame. Example:
      stop ();
      loadVarsText = new LoadVars();
      loadVarsText.load("fedNews.txt");
      //assign a function which fires when the data is loaded:
      loadVarsText.onLoad = function(success) {
      if (success) {
      trace("done loading");
      //Now that we know the data is loaded,
      //set the text content of the Text Field
      //with the instance name "scroller" equal to the
      //contents of the variable
      scroller.html=true;
      scroller.htmlText = this.var1;
      } else {
      trace("not loaded");
      In that .txt file, I'm putting the information like this:
      var1=<font face="tahoma,verdana,sans-serif" size="11px" color="#000000"><b><a href=' http://www.esi-intl.com/public/classroomtraining/dau.asp'>DAU Grants ESI Course CON353 Equivalency</a></b><br>Advanced Business Solution in Contracting (CON 353) is an equivalency for DAU's CON 3535 course, Advanced Business Solutions for Mission Support. <a href=' http://www.esi-intl.com/public/classroomtraining/dau.asp'><U><font color="#996633">Continue</font></U></a></font>
      So much of this is pick-ups from what I've researched in Google. I'm looking for a way I can feel more confident in my code, and also have that code follow CSS.
      Lastly, I recognize the problems in XML with using single quotes / double quotes, and the & symbol. This is one of my largest time sucks, and I'd like to find a better way to do this.
      Thank you
