11 Replies Latest reply on Oct 18, 2010 11:37 AM by Claudiu Ursica
    Socket and keepalive
    Zolotoj Level 3
      How do I do keepalive with Flex sockets?
        • 1. Re: Socket and keepalive
          Claudiu Ursica Level 4
          Your server ask clients for Ping CommandMessage-s at regular time intervals.
          Whichever client fails to send the ping acknowledge gets disconnected by the
          server.
          C
          • 2. Re: Socket and keepalive
            Zolotoj Level 3
            How exactly my (Flex) server would ask that?
            • 3. Re: Socket and keepalive
              There is no such thing as Flex server, maybe Haxe server if you insist using
              actionscript on server side. I am not sure what you have so far... share some
              requirements ... However you need to write the server side logic for thius
              listen for the socket connections on ports and make their management.
              C
              • 4. Re: Socket and keepalive
                Zolotoj Level 3
                <Your server ask clients for Ping CommandMessage-s at regular time intervals.
                <Whichever client fails to send the ping acknowledge gets disconnected by the
                <server.
                If Flex connects to a socket on another computer which side is sending such commands?
                • 5. Re: Socket and keepalive
                  The server is managing the clients (flex or whatever language they are they
                  written in). Every time  a client connects the server knows it since it can
                  accept or deny the connection... So for every connected client the server needs
                  to know if they are still connected so It ask them to ping. Basically the
                  "asking them" par is the CommandMessage is just a name in communication
                  software, because the server commands the client to ping it. So the server
                  issues this commands at some regular intervals for all connected clients. Which
                  ever client fails to deliver the reply for the ping command gets disconnected.
                  commands? So here the another computer is the server, since your flex client
                  connects to that computer. SO the programm running on the other compouter can be
                  java, c, air whatever issues the ping CommandMessages.
                  C
                  • 6. Re: Socket and keepalive
                    Zolotoj Level 3
                    I still dont understand.
                    I am listening in Flex to a socket on the network that nothing to do with any programming language. So, Who is pinging who?
                    • 7. Re: Socket and keepalive
                      Show me your code,
                      C
                      • 8. Re: Socket and keepalive
                        Zolotoj Level 3
                        private var socket:Socket = new Socket();
                        socket.addEventListener(Event.CONNECT, onConnect);
                        socket.addEventListener(IOErrorEvent.IO_ERROR, onError);
                        socket.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onSecurityError);
                        socket.connect(ip, 8023);
                        private function onConnect(event:Event):void
                             socket.flush();
                             socket.addEventListener(ProgressEvent.SOCKET_DATA, onData);
                        • 9. Re: Socket and keepalive
                          Now this is client code. You should be having another piece of code that is
                          listening on the IP, and port 8023. When you call socket.connect(ip, 8023); you
                          connect to a machine running that piece of code typically called server. Tah
                          code aknowledge the fact that you called connect and will send some answer back
                          to you that you are connected. That answer will treigger your onConnect for
                          which you registered with this line socket.addEventListener(Event.CONNECT,
                          onConnect); Now you can send and recieve data.
                          your onData will be called every time the application you connect to will send
                          something to you.
                          your onData should look something like this
                          private function onData(event:ProgressEvent):void
                                      var data:ByteArray = readResponse();
                                      //do whatever you want with the bytes
                          private function readResponse():ByteArray
                                      var byteArray:ByteArray = new ByteArray();
                                      socket.readBytes(byteArray, 0);
                                      return byteArray;
                          Your server will call you to ping it. So insetad of these lines
                          you should read the bytes and somehow figure out that you need to ping. Then
                          prepare a response message fluish the socket and wait.
                          you should have a close handler also:
                          socket.addEventListener(Event.CLOSE, closeHandler);
                          private function closeHandler(event:Event):void
                                      trace("closeHandler: " + event);
                                      //if this code e4xecutes you are disconnected.
                          http://livedocs.adobe.com/flex/3/html/help.html?content=17_Networking_and_communications_5 .html
                          this also helps to get a better picture .
                          C
                          • 10. Re: Socket and keepalive
                            Zolotoj Level 3
                            Like I said, I am not connecting to a socket created with any program. It is a piece of hardware that has an ip and a port.
                            • 11. Re: Socket and keepalive
                              I believe than that piece of hardware needs to come with a communication
                              protocol. And that piece of hardware acts like the server. You should have the
                              protocol specs and also what commands does that piece of hardware accepts. If it
                              doesn't ask by itself for the keepalive, maybe it has some api's exposed to
                              you...
                              C
