3 Replies Latest reply on Jul 24, 2007 7:05 AM by Peter deHaan
    Validator isn't fired when using example code from chapter 40: Validating Data
    liekeroman
      When following example code, mentioned in the Flex Developer Guide on page 1282 is copied into an mxml example application and I run the application, validation is never fired.
      When I have a look at other example code, which is using the listener- and trigger-property on the validator everything works fine.
      Could you explain why the example code from the Dev-guide doesn't work as mentioned in the guide?
