0 Replies Latest reply on Oct 15, 2010 7:36 PM by metal_312
    Web Service problem
    metal_312
      Hi everyone,
      I'm a newbie in AS2.0. I tried to test the SOAP with Webservice using 2 methods: Webservice class and XML's SendAndLoad method.
      The first one i use webservice class and run correctly
      import mx.services.*;
      celsius_txt.border=true;
      // ignore XML white space
      XML.prototype.ignoreWhite = true;
      var ConvertService = new WebService("http://www.w3schools.com/webservices/tempconvert.asmx?WSDL");
      ConvertService.onLoad=trace("loading")
      // Construct an XML object to hold the server's reply
      // this function triggers when the login_btn is clicked
      send_btn.onRelease = function() {
      trace("1");
      resultObject = ConvertService.CelsiusToFahrenheit(celsius_txt.text);
      resultObject.onResult=function(result){
         trace(result);
      The second one i use XML's SendAndLoad method to send and XML document to the Web service, but error ocurr
      var respondXML:XML = new XML();
      var requestXML:XML = new XML();
      // this function triggers when an XML packet is received from the server.
      respondXML.onLoad = function(success:Boolean) {
      if (success) {
      trace(respondXML);
      trace("3");
      requestXML.onLoad = function(success:Boolean) {
      if (success) {
      //loginXML.send("http://www.w3schools.com/webservices/tempconvert.asmx/CelsiusToFahrenheit");
      requestXML.sendAndLoad("http://tempuri.org/CelsiusToFahrenheit",respondXML);
      trace("2");
      requestXML.load("SendAndLoad.xml");
      trace("1");
      The error display when i run this script is : "Error Opening URL". I guess i have enter a wrong server address at
      This URL i got when i read the WSDL:
      http://www.w3schools.com/webservices/te ... .asmx?WSDL
      i have tried some other address, but could not figure it out.
      I attach my 2 program here, can you help me to make it work?
      Thank you very much!
