2 Replies Latest reply on Oct 16, 2010 7:29 AM by erwanhamdani
    I need this indesign cs3 script to run under Indesign cs2
    erwanhamdani
      This is paragraph changes script which is run under indesign cs 3, I need this  script to run under my indesign cs 2, can anyone help me pls?. thank you  in advance
          Fixing paragraph style combinations
          Version: 1.1
          Script by Thomas Silkjær
          http://indesigning.net/
      var the_document = app.documents.item(0);
      // Create a list of paragraph styles
      var list_of_paragraph_styles = the_document.paragraphStyles.everyItem().name;
      // Make the dialog box for selecting the paragraph styles
      var the_dialog = app.dialogs.add({name:"Fix paragraph style pairs"});
      with(the_dialog.dialogColumns.add()){
          with(dialogRows.add()){
              staticTexts.add({staticLabel:"Find:"});
          with(borderPanels.add()){
              var find_first_paragraph = dropdowns.add({stringList:list_of_paragraph_styles, selectedIndex:0});
              staticTexts.add({staticLabel:"followed by"});
              var find_second_paragraph = dropdowns.add({stringList:list_of_paragraph_styles, selectedIndex:0});
              staticTexts.add({staticLabel:"Change:"});
              var change_first_paragraph = dropdowns.add({stringList:list_of_paragraph_styles, selectedIndex:0});
              var change_second_paragraph = dropdowns.add({stringList:list_of_paragraph_styles, selectedIndex:0});
      the_dialog.show();
      // Define paragraph styles
      var find_first_paragraph = the_document.paragraphStyles.item(find_first_paragraph.selectedIndex);
      var find_second_paragraph = the_document.paragraphStyles.item(find_second_paragraph.selectedIndex);
      var change_first_paragraph = the_document.paragraphStyles.item(change_first_paragraph.selectedIndex);
      var change_second_paragraph = the_document.paragraphStyles.item(change_second_paragraph.selectedIndex);
      // Set find grep preferences to find all paragraphs with the first selected paragraph style
      app.findChangeGrepOptions.includeFootnotes = false;
      app.findChangeGrepOptions.includeHiddenLayers = false;
      app.findChangeGrepOptions.includeLockedLayersForFind = false;
      app.findChangeGrepOptions.includeLockedStoriesForFind = false;
      app.findChangeGrepOptions.includeMasterPages = false;
      app.findGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences.appliedParagraphStyle = find_first_paragraph;
      app.findGrepPreferences.findWhat = "^";
      //Search the current story
      var the_story = app.selection[0].parentStory;
      var found_paragraphs = the_story.findGrep();
      var change_first_list = [];
      var change_second_list = [];
      // Loop through the paragraphs and create a list of words and mark them as index words
      myCounter = 0;
      do {
          try {
              // Create an object reference to the found paragraph and the next
              var first_paragraph = found_paragraphs[myCounter].paragraphs.firstItem();
              var next_paragraph = first_paragraph.paragraphs[-1].insertionPoints[-1].paragraphs[0];
              // Check if the next paragraph is equal to the find_second_paragraph
              if(next_paragraph.appliedParagraphStyle == find_second_paragraph) {
                      change_first_list.push(first_paragraph);
                      change_second_list.push(next_paragraph);
          } catch(err) {}
          myCounter++;
      } while (myCounter < found_paragraphs.length);
      // Apply paragraph styles
      myCounter = 0;
      do {
          change_first_list[myCounter].appliedParagraphStyle = change_first_paragraph;
          change_second_list[myCounter].appliedParagraphStyle = change_second_paragraph;
          myCounter++;
      } while (myCounter < change_first_list.length);
      alert("Done fixing pairs!");
