7 Replies Latest reply on Oct 18, 2010 9:38 AM by Ranjaxt2012
    export to excel trusted function error.
    Ranjaxt2012 Level 1
      i understand than it is a trusted/folder level scripting function problem but can some one help me getting thought. another question, is there any way i can avoid this security message, can i totally turn off my security so that i can write a simple program and not have to go worry about all the trusted functions. Sorry for many postings, but this is very frustrating environment for a developer.
      app.addToolButton({
                 cName: "exptoexcel",
                 cExec: "myExport()",
                 cLabel: "Excell Exp",
                 cTooltext: "Creat Redar Links"
      function myExport ()
      app.trustedFunction(checkReport(this));
      function exportMyReport(doc)
      var annots = doc.getAnnots();
          var myExpFile = "Name\tPage\tComment";
          for ( var i=0; i<annots.length; i++ )
              myExpFile += ("\n"+annots[i].author + "\t" + annots[i].page + "\t\""
                  + annots[i].contents+"\"");
          doc.createDataObject({cName: "myCommentList.xls", cValue: cMyC});
          doc.exportDataObject({cName: "myCommentList.xls", nLaunch: 1});
      error message is
      NotAllowedError: Security settings prevent access to this property or method.
      App.trustedFunction:14:App exptoexcel:Exec
        • 1. Re: export to excel trusted function error.
          No, you can't turn off the security restrictions.
          You're not using the trustedFunction method correctly. Look at the reference
          to see how it's done properly.
          Another thing is you're calling checkReport in trustedFunction, while the
          name of your function is actually exportMyReport.
          Also, where do you define the parameter "cMyC" that you use in
          createDataObject ?
          And just as a general remark, you're better off exporting to a CSV file. XLS
          is a proprietry format and you can't just create a valid XLS file like that.
          CSV, on the other side, is a simple comma separated text file, which Excel
          recognizes without any problems.
          • 2. Re: export to excel trusted function error.
            Ranjaxt2012 Level 1
            Thanks i will pay attention to the other export format.
            so one is working and other one is not.
            can u tell me what am i doing wrong with more explanation.
            app.trustedFunction(checkReport(this)); // working
            app.trustedFunction(exportMyReport(this)); //not working
            function checkReport(doc)
            for (var i = 0; i < doc.numPages; i++)
            var numWords = doc.getPageNumWords(i);
                for(var j = 0; j < numWords; j++)
                    var wordCount = doc.getPageNthWord(i,j);
                    if (wordCount == "Firm")
                            var wc = j;
            for(var w = 0; w < wc; w++)
                    ckWord = doc.getPageNthWord(i,w);
                    if (ckWord == "ECM")
                            doc.addAnnot
                    page: i,
                    type: "StrikeOut",
                    quads: doc.getPageNthWordQuads(i,w),
                    author: "Anup Singh",
                    contents: ckWord.toString()
            }//wc ends
                } //end PRR statement
            }// end word loop
            }//end of finction
                doc.exportDataObject({cName: "myCommentList.xls", nLaunch: 2});
            • 3. Re: export to excel trusted function error.
              Does your file has file attachment rights?
              • 4. Re: export to excel trusted function error.
                Ranjaxt2012 Level 1
                i am not sure about file attachment. however it saves my data and launches it for me. if you want to call it file attachment then....
                • 5. Re: export to excel trusted function error.
                  Ranjaxt2012 Level 1
                  i think the problem is with trusted function.
                  • 6. Re: export to excel trusted function error.
                    Where have you established the object of the 'doc' object?
                    You might want to look at line 14 of your script and possibly place a 'console.println();' with some information about the variables you are trying to use in line 14.
                    Where is the "checkReport()' function defined?
                    • 7. Re: export to excel trusted function error.
                      Ranjaxt2012 Level 1
                      thanks all its working. your help is highly appreciated.
