5 Replies Latest reply on Nov 7, 2010 7:45 AM by eliasbalasis
    NullPointerException when opening editor
    TomBurgundy Level 1
      Hello
      Not sure if this is a known bug.. I had just opened FB this morning, and clicked the editor tab for a file (which was still there from my last session). Instead of seeing the editor, I got this exception:
      java.lang.NullPointerException
      at com.adobe.flexide.editorcore.ColoringAndStylingPreferenceManager.getColoringAndStylingCon figuration(ColoringAndStylingPreferenceManager.java:129)
      at com.adobe.flexide.as.core.ASCoreSourceViewerConfig.getPartitionScannerMap(ASCoreSourceVie werConfig.java:137)
      at com.adobe.flexide.as.core.ASCoreSourceViewerConfig.addDamagerRepairers(ASCoreSourceViewer Config.java:150)
      at com.adobe.flexide.as.core.ASCoreSourceViewerConfig.getPresentationReconciler(ASCoreSource ViewerConfig.java:98)
      at org.eclipse.jface.text.source.SourceViewer.configure(SourceViewer.java:366)
      at com.adobe.flexide.editorcore.editor.FlexSourceViewer.configure(FlexSourceViewer.java:234)
      at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:33 22)
      at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:53)
      at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecorated TextEditor.java:427)
      at com.adobe.flexide.editorcore.editor.AbstractFlexEditor.createPartControl(AbstractFlexEdit or.java:835)
      at com.adobe.flexbuilder.as.editor.ActionScriptEditor.createPartControl(ActionScriptEditor.j ava:97)
      at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
      at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
      at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
      at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
      at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180 )
      at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFo lder.java:270)
      at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder .java:65)
      at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStack Presentation.java:473)
      at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
      at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
      at org.eclipse.ui.internal.PartStack.presentationSelectionChanged(PartStack.java:843)
      at org.eclipse.ui.internal.PartStack.access$1(PartStack.java:829)
      at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.java:139)
      at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation$1.handleEvent(TabbedSt ackPresentation.java:133)
      at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder. java:270)
      at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder. java:279)
      at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder.access$1(Defau ltTabFolder.java:1)
      at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder$2.handleEvent( DefaultTabFolder.java:87)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
      at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770)
      at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3256)
      at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:2045)
      at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:323)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
      at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :109)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
        • 1. Re: NullPointerException when opening editor
          Radhakrishna Bhat Level 3
          Was the project closed or deleted before you opened editor? Can you provide more details to reproduce the problem?
          -radhakrishna
          • 2. Re: NullPointerException when opening editor
            TomBurgundy Level 1
            The project was not closed. I had just started my PC, opened FB and encountered the problem. Other editors failed to open as well.
            I then closed FB, opened it again and the bug did not appear again.
            • 3. Re: NullPointerException when opening editor
              TomBurgundy Level 1
              Good morning...
              Another Monday and the same problem again.
              I just checked the log and found a few interesting exceptions, which should get yuou started:
              !SESSION 2010-10-25 09:07:52.829 -----------------------------------------------
              eclipse.buildId=unknown
              java.version=1.6.0_16
              java.vendor=Sun Microsystems Inc.
              BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
              Command-line arguments:  -os win32 -ws win32 -arch x86
              !ENTRY com.adobe.flexbuilder.project 4 43 2010-10-25 09:08:00.051
              !MESSAGE Couldn't register *ColoringAndStylingPreferenceProvider
              !STACK 1
              org.eclipse.core.runtime.CoreException: Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.color.ActionScriptColoringAndStylingPreferenceProvider".
              at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrat egyOSGI.java:180)
              at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:174)
              at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionR egistry.java:874)
              at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Configu rationElement.java:243)
              at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(C onfigurationElementHandle.java:51)
              at com.adobe.flexide.editorcore.EditorCore.registerColoringAndStylingPreferenceProviders(Edi torCore.java:246)
              at com.adobe.flexide.editorcore.EditorCore.start(EditorCore.java:216)
              at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:7 83)
              at java.security.AccessController.doPrivileged(Native Method)
              at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:774)
              at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:7 55)
              at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:352)
              at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:280)
              at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:408)
              at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
              at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :449)
              at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:211)
              at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:381)
              at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:3 3)
              at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
              at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
              at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
              at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:105)
              at java.lang.ClassLoader.loadClass(Unknown Source)
              at java.lang.ClassLoader.loadClassInternal(Unknown Source)
              at java.lang.ClassLoader.defineClass1(Native Method)
              at java.lang.ClassLoader.defineClass(Unknown Source)
              at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.j ava:183)
              at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:57 6)
              at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java: 546)
              at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager. java:477)
              at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(Class pathManager.java:465)
              at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :445)
              at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:457)
              at com.adobe.flexbuilder.as.editor.ui.views.CallHierarchyView.<init>(CallHierarchyView.java: 418)
              at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
              at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
              at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
              at java.lang.reflect.Constructor.newInstance(Unknown Source)
              at java.lang.Class.newInstance0(Unknown Source)
              at java.lang.Class.newInstance(Unknown Source)
              at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Re gistryStrategyOSGI.java:170)
              at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
              at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
              at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
              at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:63)
              at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:324)
              at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:226)
              at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:529)
              at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:668)
              at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:576)
              at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
              at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
              at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:982)
              at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2626)
              at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:2965)
              at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2946)
              at org.eclipse.ui.internal.WorkbenchWindow$21.runWithException(WorkbenchWindow.java:2263)
              at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
              at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
              at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
              at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
              at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
              at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
              at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
              at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
              Caused by: java.lang.ClassCircularityError: com/adobe/flexide/editorcore/document/IFlexDocument
              at java.lang.Class.getDeclaredConstructors0(Native Method)
              at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
              at java.lang.Class.getConstructor0(Unknown Source)
              ... 105 more
              !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-10-25 09:08:00.053
              !MESSAGE Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.color.ActionScriptColoringAndStylingPreferenceProvider".
              !STACK 0
              !ENTRY com.adobe.flexbuilder.project 4 43 2010-10-25 09:08:00.452
              !MESSAGE Couldn't register *FileTemplatesProvider
              !STACK 1
              org.eclipse.core.runtime.CoreException: Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.filetemplates.ActionScriptFileTemplatesProvider".
              at com.adobe.flexide.editorcore.EditorCore.registerFileTemplatesProviders(EditorCore.java:27 5)
              at com.adobe.flexide.editorcore.EditorCore.start(EditorCore.java:217)
              ... 105 more
              !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-10-25 09:08:00.454
              !MESSAGE Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.filetemplates.ActionScriptFileTemplatesProvider".
              !STACK 0
              !ENTRY com.adobe.flexbuilder.editorcore 4 1 2010-10-25 09:26:00.444
              !MESSAGE Error creating pages for Code and Design editor
              !STACK 0
              at com.adobe.flexide.as.core.color.FastActionScriptScanner.<init>(FastActionScriptScanner.ja va:327)
              at com.adobe.flexide.mxml.core.editor.MXMLCoreSourceViewerConfig.getPartitionScannerMap(MXML CoreSourceViewerConfig.java:234)
              at com.adobe.flexide.mxml.core.editor.MXMLCoreSourceViewerConfig.getPresentationReconciler(M XMLCoreSourceViewerConfig.java:257)
              at com.adobe.flexbuilder.mxml.editor.code.MXMLCodeEditor$MXMLSourceViewer.configure(MXMLCode Editor.java:577)
              at com.adobe.flexide.editorcore.editor.AbstractModelAwareEditor.createPartControl(AbstractMo delAwareEditor.java:50)
              at com.adobe.flexbuilder.mxml.editor.code.MXMLCodeEditor.createPartControl(MXMLCodeEditor.ja va:304)
              at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:242)
              at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:212)
              at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.createPages(CodeAndDesignEdit or.java:209)
              at com.adobe.flexbuilder.mxml.editor.MXMLEditor.createPages(MXMLEditor.java:217)
              at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
              at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
              at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
              at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
              at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
              at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
              at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
              at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
              at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
              at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
              at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
              at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
              at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
              at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
              at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
              at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
              at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
              at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
              at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
              at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
              at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
              at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
              at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
              at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
              at com.adobe.flexbuilder.editors.derived.ui.navigator.FlexMainActionGroup.runDefaultAction(F lexMainActionGroup.java:350)
              at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
              at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
              at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHel per.java:48)
              at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
              at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
              at org.eclipse.core.runtime.Platform.run(Platform.java:888)
              at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
              at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
              at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
              at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
              at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
              at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
              at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
              at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
              !ENTRY org.eclipse.ui 4 0 2010-10-25 09:26:00.586
              !MESSAGE Unable to create editor ID com.adobe.flexbuilder.editors.mxml.MXMLEditor: assertion failed:
              !STACK 0
              org.eclipse.core.runtime.AssertionFailedException: assertion failed:
              at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
              at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
              at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1074)
              at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.setActivePage(CodeAndDesignEd itor.java:683)
              at com.adobe.flexbuilder.mxml.editor.MXMLEditor.setActivePage(MXMLEditor.java:544)
              at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:361)
              !ENTRY org.eclipse.ui 4 0 2010-10-25 09:27:07.095
              !MESSAGE Unable to create editor ID com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor: An unexpected exception was thrown.
              !STACK 0
              • 4. Re: NullPointerException when opening editor
                It would be great if you are able to give specific steps to reproduce the issue. It seems it doesn't happen always for you.
                Can you please log a bug in jira https://bugs.adobe.com/flex with reproducible steps and log.
                -Radhakrishna
                • 5. Re: NullPointerException when opening editor
                  eliasbalasis Level 1
                  I had a similar problem when tried to run Modeling plug-in on Eclipse 3.6 thus discovering that the plug-in is incompatible with Eclipse 3.6
                  stack trace is similar
                  see also http://forums.adobe.com/thread/748772 for more details
                  I hope this helps
