5 Replies Latest reply on Mar 23, 2011 5:34 PM by Dan Zen
    Modal popup background color
    daslicht Level 2
      Hello,
      when you add a modal Popup the rest of the application is "grayed out" (disabled).
      How can I change this color ? A dark color would be better matching.
        • 1. Re: Modal popup background color
          BhaskerChari Level 4
          Hi daslicht,
          You can use modalTransparencyColor="#000000"  on the main application root tag..so that this color will be applied for all modal windows.
          <mx:Application modalTransparencyColor="#000000/>
          Bhasker
          • 2. Re: Modal popup background color
            sekhar7650
            Hi
            model pop up background color source code it is useful to you
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            layout="vertical"
            verticalAlign="middle"
            backgroundColor="white"
            creationComplete="init();">
            <mx:Script>
            <![CDATA[
            import mx.controls.Alert;
            import mx.styles.StyleManager;
            private var alert:Alert;
            private var alertCSS:CSSStyleDeclaration;
            private function init():void {
            alertCSS = StyleManager.getStyleDeclaration("Alert");
            private function showAlert(color:Object):void {
            alertCSS.setStyle("modalTransparencyColor", color);
            alertCSS.setStyle("themeColor", color);
            alert = Alert.show("The quick brown fox...");
            </mx:Script>
            <mx:ApplicationControlBar dock="true">
            <mx:Button label="Red"
            themeColor="red"
            click="showAlert('red');" />
            <mx:Button label="Orange"
            themeColor="haloOrange"
            click="showAlert('haloOrange');" />
            <mx:Button label="Yellow"
            themeColor="yellow"
            click="showAlert('yellow');" />
            <mx:Button label="Green"
            themeColor="haloGreen"
            click="showAlert('haloGreen');" />
            <mx:Button label="Blue"
            themeColor="haloBlue"
            click="showAlert('haloBlue');" />
            </mx:ApplicationControlBar>
            </mx:Application>
            regards
            sekhar7650
            • 3. Re: Modal popup background color
              Hi sekhar,
              This will work only for Alert window modal popup's but not for the popup's opened using PopUpManager class but its a good approach for dynamically changing the Alert css styles in AS.
              But by specifying the modalTransparencyColor on root application tag applies to all modal windows including the Alert windows.
              Bhasker
              • 4. Re: Modal popup background color
                daslicht Level 2
                modalTransparencyColor ="#000000"
                This property is not available for a Spark Application, but I just found this:
                <fx:Style>
                        global {
                        modalTransparencyBlur: 0;
                        modalTransparency: .5;
                        modalTransparencyColor: #000000;
                </fx:Style>
                and
                http://forums.adobe.com/thread/526872
                modalTransparencyColor was the keyword I was looking for , thakt you very much !
                • 5. Re: Modal popup background color
                  Dan Zen Level 1
                  Also, if you want to change just the modal properties for a specific spark component in a popup then set the spark component styleName="modalStyle" or some such thing and then in your style tag do something like (so it does not have to be put in a global style):
                  <fx:Style>
                       .modalStyle {modal-transparency: .1; modal-transparency-blur:1;}
                  </fx:Style>
