2 Replies Latest reply on Oct 27, 2010 12:04 AM by Anonym2010
    Unable to export air application?
      Hello guys,
      i'm trying to write an air application and try to test it. The application can be started in Flash CS 5 Professional without a problem. When I try to export it as air application, it says "Error. xxxxxx\xxxxxx\xxxx-app.xml:
      error 306: Descriptor must support the profile desktop,mobileDevice, or extendedMobileDevice
      Picked up _JAVA_OPTIONS:-Dsun.java2d.d3d=false" I recognized this setting, because I needed to set it, to get ArgoUML to run with 2 monitors. If I delete this system variable, everything works fine, but I can't use ArgoUML anymore, which is a problem. Could you please help me?
