2 Replies Latest reply on Oct 24, 2010 12:01 PM by philhog73
    Collision detect script = not responding
    philhog73 Level 1
      Hi, I am currently attempting to make an interactive 3D game with landscape and character made in 3DS Max 2010. I have been following Deans Director Tutorials and I have used the same code slightly altered because I have only one camera and the character is using bonesplayer. This all worked well until I tried to add code from the collision detect 2 tutorial and when I pressed play it would not load. From here I disabled the register for events line and it played minus the actual detection of the mountain landscape, etc. Hope this makes sense. I am a complete newbie and apologize if it doesn't. Any help would be really appreciated.
      Working code before adding collision detect script:-
      -- create properties for when arrow keys are pressed
      -- properties will either be TRUE or FALSE values
      property pLeftArrow, pRightArrow, pDownArrow, pUpArrow
      property p3Dmember -- reference to 3D cast member
      property pSprite -- referebce to the 3D sprite
      property pCharacter -- reference to character in the 3D world
      on beginSprite me
      -- initiate properties and 3D world
      pSprite = sprite(me.spriteNum)
      p3Dmember = sprite(me.spriteNum).member
      p3Dmember.resetWorld()
      pMember = pSprite.member
      pCharacter = p3Dmember.model("hero")
      pCharacter.bonesPlayer.playRate = 0
      -- we must define pCharacter after we use the
      -- resetWorld() command otherwise this variable
      -- object will be deleted
      setUpCamera
      end
      on setUpCamera
      -- create 1 new cameras
      characterCam = p3Dmember.newCamera("characterCam")
      -- characterCam settings
      -- set up the camera's vertical viewing angle
      characterCam.fieldOfView = 75
      -- position the camera
      characterCam.transform.position = vector(-1250,0,450)
      -- set rotation of camera
      characterCam.transform.rotation = vector(90,0,270)
      -- set the camera of the sprite to the characterCam
      pSprite.camera = p3Dmember.camera("characterCam")
      -- make cameras children of the character model
      pCharacter.addChild(characterCam,#preserveParent)
      end
      on keyDown
      -- check to see which key has been pressed
      -- and set the property relating to that key to TRUE
      -- 123 = left arrow key
      if keypressed(123) then pLeftArrow = TRUE
      -- 124 = right arrow key
      if keypressed(124) then pRightArrow = TRUE
      -- 125 = down arrow key
      if keypressed(125) then pDownArrow = TRUE
      -- 126 = up arrow key
      if keypressed(126) then pUpArrow = TRUE
      end
      on keyUp
      -- when the arrow keys are released,
      -- set the properties to FALSE
      pLeftArrow = FALSE
      pRightArrow = FALSE
      pUpArrow = FALSE
      pDownArrow = FALSE
      end
      on exitFrame
      characterMove
      end
      on characterMove
      -- if the right arrow is pressed,
      -- rotate the character 5 degrees about the z-axis
      if pRightArrow then
      pCharacter.rotate(0,0,-5)
      end if
      --if the left arrow is pressed,
      -- rotate character -5 degrees about the z-axis
      if pLeftArrow then
      pCharacter.rotate(0,0,5)
      end if
      -- if the up arrow is pressed,
      -- move the character 5 pixels along the y-axis
      if pUpArrow then
      pCharacter.bonesPlayer.playRate = 2
      pCharacter.translate(15,0,0)
      end if
      -- if the down arrow is pressed,
      -- move the character -5 pixels along the y-axis
      if pDownArrow then
      pDownArrow = FALSE
      pCharacter.translate(-15,0,0)
      end if
      end
      With added collision detect script:-
      property pSprite -- reference to the 3D sprite
      property pCharBoundingBox -- reference to character's bounding box
      on beginSprite me
      setUpCamera
      createCharacterBoundingBox
      -- register the member for regular timeMS events in order to respond to
      -- user input and resolve camera collisions
      -- i.e. after specified time segments activate collisionDetect handler
      p3Dmember.registerForEvent(#timeMS,#collisionDetect,me,1000,10,0)
      end
      on createCharacterBoundingBox
      -- create model resource
      charModRes = p3Dmember.newModelresource("charModRes",#box)
      charModRes.height = 200
      charModRes.width = 200
      charModRes.length = 400
      -- create model and reference to it
      pCharBoundingBox = p3Dmember.newModel("CharBoundingBox",charModRes)
      pCharBoundingBox.worldPosition = pCharacter.worldPosition
      pCharacter.addChild(pCharBoundingBox, #preserveworld)
      boxShader = p3Dmember.newShader("transparentShad",#standard)
      boxShader.transparent = TRUE
      -- set opacity of shader 0 is invisible - only works if transparent prop = TRUE
      boxShader.blend = 50
      pCharBoundingBox.shaderList = p3Dmember.shader("transparentShad")
      end
      on setUpCamera
      end
      on collisionDetect me
      -- create a list to store collision data created by modelsUnderRay
      -- cast ray to left
      collisionList = p3Dmember.modelsUnderRay(pCharBoundingBox.worldPosition, \
      -pCharacter.transform.yAxis,#detailed)
      -- if ray picks up models, then activate checkForCollion
      -- handler and send the collisionList as a parameter
      if (collisionList.count) then me.checkForCollision(collisionList[1])
      -- cast ray to right
      -- if ray picks up models, then check for collision
      -- cast ray forward
      pCharacter.transform.xAxis,#detailed)
      -- cast ray backward
      -pCharacter.transform.xAxis,#detailed)
      end
      on checkForCollision me, collisData
      -- grab the #distance value from the CollisionList
      dist = collisData.distance
      -- check if distance is less than width of bounding box
      if (dist < pCharBoundingBox.resource.width/2) then
      -- get distance of penetration
      diff = pCharBoundingBox.resource.width/2 - dist
      -- calculate vector perpendicular to the wall's surface to move the character
      -- using the #isectNormal property
      tVector = collisData.isectNormal * diff
      -- move the character in order to resolve the collision
      pCharacter.translate(tVector,#world)
      end if
      end
      on keyDown
      end
      on keyUp
      pLeftArrow = FALSE
      pRightArrow = FALSE
      pUpArrow = FALSE
      pDownArrow = FALSE
      end
      on exitFrame
      characterMove
      end
      on characterMove
      if pRightArrow then
      end if
      if pLeftArrow then
      end if
      if pUpArrow then
      end if
      if pDownArrow then
      pDownArrow = FALSE
      end if
      end
        • 1. Re: Collision detect script = not responding
          Dean Utian Adobe Community Professional
          Hi Phillip.
          Always worth being concise as possible with your problem.
          Problem could be a complex 3D world and too much processing going on with teh modelUnderRay. Try add the following:
            tModelList = [p3Dmember.model("model1"), p3Dmember.model("model2")]
            tOptionsList = [#maxNumberOfModels: 2, #levelOfDetail: #detailed, #modelList: tModelList, #maxDistance: 200]
            -- cast ray forward
            collisionList = p3Dmember.modelsUnderRay(pCamera.worldPosition,  pCamera.transform.zAxis, tOptionsList)
          In the above, tModelList specifies all the models you want to test collsion with. You may not need collision detection with everything.
          tOptionsList defines the maximum number of models (based on tModelList) and the maximum distance of the ray. You don’t need an infinitely long ray as you’re only concerned with objects close to your character.
          Dean
          • 2. Re: Collision detect script = not responding
            philhog73 Level 1
            Hi Dean,
            Thanks for your quick response.  I have struggled using the code with my script so have tried to concentrate on the key code you gave me first and this has worked quite well.  The character now continues walking once you have pressed the left or right arrow button, but, down to my lack of director knowledge, the walk-cycle continues once I release a finger from the arrow keys.  This is my code at the moment;-
            property keylist
            property keypresslist
            on beginSprite me
              --we must define pCharacter after we use the
              --resetWorld() command otherwise this variable
              --object will be deleted
              setUpCamera
              keylist = []
              keypresslist = []
              -- this sets up a list of keycodes to track.
              -- this code covers the arrow keys only, it could be changed to cover a full range of keys
              repeat with i = 123 to 126
                keylist[i] = i   -- this creates a list of keycodes to track
                keypresslist[i] = 0  -- this creates a "last state" list that corresponds to the keycode.
                --keypresslist tracks the last known state of that key, so we can tell when a keypress has changed.
              end repeat
            end
            on enterFrame me
              -- this runs every frame.
              repeat with i = 1 to keylist.count
                inewstate= keypressed( keylist[i] )
                if keypresslist[i] <> inewstate then -- this means the key changed status from whether it's up or down
                  if inewstate= 0 then
                    -- they key was released
                    keyLastReleased = keylist[i]
                    if (keyLastReleased=123) then pLeftArrow  = 0 -- 123 = left arrow key
                    if (keyLastReleased=124) then pRightArrow = 0 -- 124 = right arrow key
                    if (keyLastReleased=125) then pDownArrow  = 0 -- 125 = down arrow key
                    if (keyLastReleased=126) then pUpArrow    = 0 -- 126 = up arrow key
                  else
                    -- the key was pressed
                    keyLastPressed = keylist[i]
                    if (keyLastPressed=123) then pLeftArrow  = 1 -- 123 = left arrow key
                    if (keyLastPressed=124) then pRightArrow = 1 -- 124 = right arrow key
                    if (keyLastPressed=125) then pDownArrow  = 1 -- 125 = down arrow key
                    if (keyLastPressed=126) then pUpArrow    = 1 -- 126 = up arrow key
                  end if
                  keypresslist[i] = inewstate-- update so we remember its new state.
                end if
              end repeat
              -- by the time this repeat loop has finished, keypresslist will contain a complete index of what keys
              -- are held down, and which aren't.
              -- Note: most keyboards have a limit on how many keys they'll track simultaneously.
            end
            on setUpCamera
            end
            on exitFrame
              characterMove
              end
            on characterMove
              if pRightArrow then
              end if
              if pLeftArrow then
              end if
              if pUpArrow then
              end if
              if pDownArrow then
                pDownArrow = FALSE
              end if
            end
