8 Replies Latest reply on Oct 19, 2010 5:44 AM by welcomecan
    flexdatagrid within combobox issue?
    welcomecan Level 1
      hai friends,
            i am using dynamic datagrid . it include one of the  column include a dynamic combobox.
      for example
      that a dynamic combobox include like
      1
      10
      50
      100
      200
      then i retrive data like this its from db.
      sec_rights_level ---> db field name
      50   --- > first data
      1     ---> second data
      100   ---> 3rd data
      10
      200
      i want selected value(50)  in first row cmbox then
      i want selected value(1) in second row combobox.    i gave like this
      <s:combobox dataprovider={outdocument.cb_dynamiccb}   selected item={data.db field name}/>// output is not coming
      give solution
      thanks in advance
      regards,
      welcome canv
        • 1. Re: flexdatagrid within combobox issue?
          Anitha Selvaraj Level 2
          Try the below code.
          private function setSelectedItem():void {
              combo.selectedItem = data.db field name;
          <s:combobox id="combo" dataprovider={outdocument.cb_dynamiccb} creationComplete="setSelectedItem()"/>
          I have also faced a similar problem and the above fix worked for me. I guess, in your code before even setting the dataprovider, the control tries to set the selectedItem for comboBox. Thats why the code is not working.
          Regards,
          Anitha
          • 2. Re: flexdatagrid within combobox issue?
            welcomecan Level 1
            but id name not display  within script.check it .
            my code is below:
            <fx:script>
            <![CDATA[
            private
            cb_combo.selectedItem = data.db field name;//  combobox id is not coming.i am getting error.
            <mx:DataGrid
            id="dg_curtainmanager" showHeaders="true" creationComplete="" variableRowHeight="true" wordWrap="true" dataProvider="{fileListArray}" rowCount="{fileListArray.length}" width="100%" >
            <mx:DataGridColumn
            headerText="Rights Level" width="100" minWidth="75" sortable="true" >
            <mx:itemRenderer >
            <fx:Component>
            <mx:HBox>
            <mx:ComboBox id="cb_combo" dataProvider="{outerDocument.first.dataProvider}" labelField="sec_rights_level" creationComplete="setSelectedItem()" />
            <mx:Label id="lbl_dfcprightlevel" text="{data.dfcp_sec_rights_level}" color="black" />
            </mx:HBox>
            </fx:Component>
            </mx:itemRenderer>
            </mx:DataGridColumn>
            </mx:DataGrid>
            • 3. Re: flexdatagrid within combobox issue?
              Add the fx:Script inside the Hbox. that is just above the combo box tag.
              • 4. Re: flexdatagrid within combobox issue?
                welcomecan Level 1
                Parse error: '<fx:Script>' is not allowed to follow '</mx:HBox>'
                • 5. Re: flexdatagrid within combobox issue?
                  Your code should be something like this.
                  <mx:DataGrid id="dg_curtainmanager" showHeaders="true" creationComplete="" variableRowHeight="true" wordWrap="true" dataProvider="{fileListArray}" rowCount="{fileListArray.length}" width="100%" >
                          <mx:DataGridColumn    headerText="Rights Level" width="100" minWidth="75" sortable="true" >
                              <mx:itemRenderer >
                                  <fx:Component>
                                      <mx:HBox>
                                          <fx:Script>
                                              <![CDATA[
                                          </fx:Script>
                                      </mx:HBox>
                                  </fx:Component>
                              </mx:itemRenderer>
                      </mx:DataGrid>
                  • 6. Re: flexdatagrid within combobox issue?
                    welcomecan Level 1
                                <mx:itemRenderer >
                                    <fx:Component>
                                        <mx:HBox>
                                            <fx:Script>
                                                <![CDATA[
                                                        cb_combo.selectedItem = data.db field name;//output is not coming
                                            </fx:Script>
                                        </mx:HBox>
                                    </fx:Component>
                                </mx:itemRenderer>
                        </mx:DataGrid>
                    • 7. Re: flexdatagrid within combobox issue?
                      Is that working? or still facing issues?
                      • 8. Re: flexdatagrid within combobox issue?
                        welcomecan Level 1
                        still same issue;
