7 Replies Latest reply on Oct 19, 2010 12:51 PM by real_ideveloper
    How can I use the CustomEvent in custom Item Renderer
    real_ideveloper
      Hi all.
      I have a small problem, which i must solve.
      I have a ImageRenderer - TileList with a custom ItemRenderer.
      When I choose a picture a button appears (in the ItemRenerer) and when I click it it throws an event with the name of the picture.
      The Problem is, that i can not add an event Listener to the ItemRenderer.
      Can anybody help me to resolve this problem?
        • 1. Re: How can I use the CustomEvent in custom Item Renderer
          Claudiu Ursica Level 4
          Why can't you add listener?
          C
          • 2. Re: How can I use the CustomEvent in custom Item Renderer
            real_ideveloper Level 1
            Bacause the itemRenderer must be an element of IFactory
            itemRenderer = "new ClassFactory(ThumbnailRenderer)"
            And there are no methonds but only the newInstance()
            this.itemRenderer.newInstance()
            • 3. Re: How can I use the CustomEvent in custom Item Renderer
              I might be missing bits and pieces however wherever you set this line
              you should be inseide a list or inside some UIComponent (Gruop or whatever)
              so if you dispatch a custom event from inside the ThumbnailRenderer you can let
              it bubble to the list or that component....
              Again maybe I am missing something...
              C
              • 4. Re: How can I use the CustomEvent in custom Item Renderer
                saisri2k2 Level 4
                Could you please paste the renderer code here?
                • 5. Re: How can I use the CustomEvent in custom Item Renderer
                  But how can I catch it in the top of the list??????
                  The ItemRenderer is a IFactory Class Object, which has only one function newInstance().
                  I repeat it again, there is no addEventListener or something else for the ItemRenderer.
                  I can give you only a header of the code because it is a big project (and if somebody have a solution or an example, maybe he could give me the it, please)
                  <mx:TileList xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init();"
                       dataProvider="{imageList}"
                       labelField="label"
                       iconField="thumbnail"
                       itemRenderer="{new ClassFactory(ThumbnailRenderer)}" verticalScrollPolicy="auto">
                  and the renderer
                  <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml"
                            horizontalAlign="center" verticalAlign="middle" creationComplete="init()"
                            xmlns:DataModels="DataModels.*"
                            click="selectedHandler()" height="125">
                       <mx:Image source="{data.thumbnail}"
                                width="80"
                                height="50"
                                      horizontalCenter="0"
                                   verticalCenter="0" horizontalAlign="center" verticalAlign="middle"/>
                       <mx:Label text="{data.label}"
                                 bottom="0" />
                       <mx:Metadata>
                           [Event(name="addImageEvent", type="DataModels.AddImageEvent")]
                      </mx:Metadata>
                  The button is created dynamicly. When i clicked it, then i dispatch a new AddImageEvent
                  like this
                  button.addEventListener(MouseEvent.CLICK, dispatchAddImageEvent);
                  private function dispatchAddImageEvent(event:Event):void
                       var addImageEvent:AddImageEvent = new AddImageEvent(AddImageEvent.ADD_IMAGE_EVENT);
                       dispatchEvent(addImageEvent);
                  Inside the renderer i can catch it, because there is the addEventListener method, but not in the ITEMRENDERER (IFactory element)
                  • 6. Re: How can I use the CustomEvent in custom Item Renderer
                    NOw I am pasting code modified from some project however you'll get the idea.
                    inside item renderer:
                        private function clickHandler(event:MouseEvent):void
                                    event.stopImmediatePropagation();
                                    dispatchEvent(new CustomEvent(CustomEvent.ADD_IMAGE,
                    PayloadObjectIfNecessary, true));
                    Notice the true for bubbling.
                    inside the tile list you can register for the event (onCreationOmplete or othere
                    method)
                    this.addEventListener(CustomEvent.ADD_IMAGE, handleEventInsideTileList);
                    inside tileList's parent
                    this.tileList.addEventListener(CustomEvent.ADD_IMAGE,
                    handleEventInsideTileListsParentOnTheListInstance);
                    assuming tileList is the TileList's id
                    or listen ont the tileList parent
                    handleEventInsideTileListParentOnTheParentInstance);
                    C
                    • 7. Re: How can I use the CustomEvent in custom Item Renderer
                      Thank you.
                      Setting the Bubble to true was the solution.
