5 Replies Latest reply on Oct 20, 2010 9:36 PM by BhaskerChari
    How to dispatch keyboard escape fake event ?
    Mohit Verma1234 Level 1
      Hi guys
        i stuck in a problem . actually i want to know if there is any way to dispatch fake escape event in flex.
        i mean dispatching a custom event of pressing the keyboard escape key fakely.
      Thanks and regards
        Mohit
        • 1. Re: How to dispatch keyboard escape fake event ?
          BhaskerChari Level 4
          Hi Mohith,
          You can try this code...
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
          <mx:Script>
            <![CDATA[
             import mx.effects.Fade;
             import mx.controls.Alert;
             public function init():void
                 this.addEventListener(KeyboardEvent.KEY_DOWN, onKeyDown);
                public function onKeyDown(event:KeyboardEvent):void
                 if(event.keyCode == Keyboard.ESCAPE)
                  Alert.show("Esc key pressed : keyCode =" + event.keyCode + "");
                   private function fakeEscKeyEvent():void {
              var keyEvent:KeyboardEvent = new KeyboardEvent(KeyboardEvent.KEY_DOWN, true, false, Keyboard.ESCAPE, Keyboard.ESCAPE);
              this.dispatchEvent(keyEvent);
          </mx:Script>
          <mx:Button label="Fake Esc Key Press" click="fakeEscKeyEvent();" />
          </mx:Application>
          Bhasker
          • 2. Re: How to dispatch keyboard escape fake event ?
            Hi Bhasker
            Thanks for replying . The code that u have provided works but what is my problem is actually i am dispatching the fake event on mouseout of main application
              in air.
            Because i am using menubar component  mx:menubar . so what i want to do is actually close the menubar component submenu popup  on mouseout by dispactching the fake escape event
            i have implemented the code that u have provided but it is not closing menubar.'
            Thanks and Regards
              Mohit
            • 3. Re: How to dispatch keyboard escape fake event ?
              Hi Mohith,
              You need to manually hide the menus when you mouseOut of the application something like as shown below...
              You need to get the index of the menu opened and need to hide the menu based on the index..
              var menu:Menu = menuBar.getMenuAt(0); //This is for first menu, you need to check for which menu was opened
              menu.hide();
              But you need to somehow manage and find when your menu is mouseOut and then execute the above code...
              Bhasker
              • 4. Re: How to dispatch keyboard escape fake event ?
                Hi BhaskerChari
                Now it works.
                Thanks for answering and helping.
                Thanks and regards
                Mohit
                • 5. Re: How to dispatch keyboard escape fake event ?
                  Hi Mohit,
                  Does it worked with the menu.hide() approach....?? How did u manage your mouseOut event on the Application ..Can you share the sample working code...:)
                  Can you please mark this post as answered.
                  Bhasker
