0 Replies Latest reply on Oct 19, 2010 5:51 AM by RobX82
    PHP Server Side Typing, Arrays, and User Defined Types
    RobX82 Level 1
      Both these pages, Page 1 and Page 2, from Adobe show that you can use server side type hinting with PHP and Flex.
      The issue I am having is that when returning an array of a user defined type, I must also have a function that returns just the user defined type itself in order for flex to recognize the array.  In the example below if I delete the getEmployeesByID function and its docblock, Flex will show the getAllEmployees function returning as an Object[] instead of Employee[].  However if I leave the second function in the php then Flex will correctly show the getAllEmployees as returning Employee[].  This is a issue because not every class is going to return both a single instance of a user defined type when I might only want to return an array of my UDT.  Does anyone know how to get around this limitation?
      <?php
      class Employee {
         * @var int
        var $emp_id;
         * @var string
        var $bdate;
      class EmployeeService {
           * Returns all the rows from the table.
           * Add authorization or any logical checks
           * for secure access to your data
           * @return Employee[]
          public function getAllEmployees() {
              return $rows;
           * @param int $itemID
           * @return Employee
          public function getEmployeesByID($itemID) {
              return $item;
