ecrystal,
First and foremost, all flash anims need to be configured to
run at 30fps.
Even if your movie authored in Flash is set to run at
alternate optimum settings (for ex: 15 or 18 fps), the fact is that
by the time you import it onto a slide in PowerPoint and then
publish your deck, Presenter will "jack up" the frame rate to match
the fps setting of the main swf file (which I think is viewer.swf)
that calls the animation that you've built.
Bottom line: it's just better to start off with 30 fps to
begin with so that you can avoid all the extra hassle.
Rob
visit my new Breeze/Presenter forums at:
www.robrode.com/yabb/
