1 Reply Latest reply on Oct 19, 2010 3:42 PM by Ned Murphy
    gotoAndPlay using variables
    BillG-Seattle Level 1
      I have a timeline that contains several named keyframes (e.g., topic1, topic 2, topic3, etc.) What I want to do is create a Next button so that, when released, the timeline would jump to the next topic. I am having difficulty, though, in figuring out how to code it so that the topic updates automatically as the timeline plays. Any thoughts would be greatly appreciated.
        • 1. Re: gotoAndPlay using variables
          To use the same button for all movement, you could have a variable that you assign the number of the current label section (1,2,3,4,etc) when you reach the sections labelled frame, and when you click the button it issues a command using that number+1... for instance, if the variable is named "tn"
          gotoAndStop("topic"+(tn+1));
          So in the frame labeled topic1, you would assign tn = 1.  That way, the tn value is current (which might be useful otherwise as well) and the button will bring you to topic2
