1 Reply Latest reply on Oct 20, 2010 6:13 AM by made_fc
    Using flex4.1, Flash Builder giving error "flash.filesystem::StorageVolume could not be found."
    made_fc
      Hi there,
                I'm trying to copy some files to Storage Card on a AIR application. Is this possible with the latest version of the AIR SDK (2.0)?
                I am developing in Flash Builder. I have downloaded the lastest flex sdk(4.1)  and used it.
                Flash Builder then recognises the StorageVolume and StorageVolumeInfo classes. However when I then run the app the debugger throws an error on the following line:
      LINE:
      var volumes:Vector.<StorageVolume> = StorageVolumeInfo.storageVolumeInfo.getStorageVolumes();
      Note: I have imported both classes as well.
        • 1. Re: Using flex4.1, Flash Builder giving error "flash.filesystem::StorageVolume could not be found."
          made_fc Level 1
          I'v read the article
          http://forums.adobe.com/message/2984004#2984004,
          and checked my application.xml, The content of the first two lines is:
          <?xml version="1.0" encoding="utf-8" standalone="no"?>
          <application xmlns="http://ns.adobe.com/air/application/2.0">
          Error message from flash builder debug:
          typecheck Player/getLocalVideo()
            outer-scope = [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ mx.core::FlexSprite$ mx.core::UIComponent$ spark.components.supportClasses::SkinnableComponent$ spark.components.supportClasses::SkinnableContainerBase$ spark.components::SkinnableContainer$ spark.components::Application$ spark.components::WindowedApplication$ Player$]
                                 [Player[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {} ()
            0:debugfile "D:\My Documents\Adobe Flash Builder 4\LiveVideoClient\OnSiteEnforceLawPublish\src;;Player.mxml"
            2:debugline 20
            4:getlocal0
                                 [Player[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {} (Player[O])
            5:pushscope
                                 [Player[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {Player[O]} ()
            6:pushnull
                                 [Player[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {Player[O]} (null[O])
            7:coerce_s
                                 [Player[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {Player[O]} (String?[S])
            8:setlocal 5
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] *[A] *[A] *[A] *[A] *[A]] {Player[O]} ()
            10:pushnull
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] *[A] *[A] *[A] *[A] *[A]] {Player[O]} (null[O])
            11:coerce mx.collections::ArrayCollection
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] *[A] *[A] *[A] *[A] *[A]] {Player[O]} (mx.collections::ArrayCollection?[O])
            13:setlocal 6
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] *[A] *[A] *[A] *[A]] {Player[O]} ()
            15:pushnull
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] *[A] *[A] *[A] *[A]] {Player[O]} (null[O])
            16:coerce flash.filesystem::File
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] *[A] *[A] *[A] *[A]] {Player[O]} (flash.filesystem::File?[O])
            18:setlocal 7
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] *[A] *[A] *[A]] {Player[O]} ()
            20:pushnull
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] *[A] *[A] *[A]] {Player[O]} (null[O])
            21:coerce_s
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] *[A] *[A] *[A]] {Player[O]} (String?[S])
            22:setlocal 8
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] String?[S] *[A] *[A]] {Player[O]} ()
            24:pushnull
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] String?[S] *[A] *[A]] {Player[O]} (null[O])
            25:coerce_s
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] String?[S] *[A] *[A]] {Player[O]} (String?[S])
            26:setlocal 9
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] String?[S] String?[S] *[A]] {Player[O]} ()
            28:debug
            33:debug
            38:debug
            43:debug
            48:debug
            53:debug
            58:debug
            63:debug
            68:debug
            73:debug
            78:debugline 23
            80:findpropstrict flash.filesystem::StorageVolumeInfo
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] String?[S] String?[S] *[A]] {Player[O]} (Object[A])
            82:getproperty flash.filesystem::StorageVolumeInfo
                                 [Player[O] *[A] *[A] *[A] *[A] String?[S] mx.collections::ArrayCollection?[O] flash.filesystem::File?[O] String?[S] String?[S] *[A]] {Player[O]} (*[A])
            84:getproperty storageVolumeInfo
            86:callproperty getStorageVolumes 0
            89:coerce __AS3__.vec::Vector
          VerifyError: Error #1014: Class flash.filesystem::StorageVolume could not be found.
          at Player/___Player_WindowedApplication1_windowComplete()[D:\My Documents\Adobe Flash Builder 4\LiveVideoClient\OnSiteEnforceLawPublish\src\Player.mxml:4]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.core::UIComponent/dispatchEvent()[E:\dev\4.x\frameworks\projects\framework\src\mx\core \UIComponent.as:12528]
          at spark.components::WindowedApplication/enterFrameHandler()[E:\dev\4.x\frameworks\projects\ airspark\src\spark\components\WindowedApplication.as:2355]
