1. Re: LR 3 - hierarchical export by date possible?
Dorin Nicolaescu-Musteață Oct 20, 2010 7:27 AM (in response to tplowe56)Do it on import.
2. Re: LR 3 - hierarchical export by date possible?
tplowe56 Oct 20, 2010 8:42 AM (in response to Dorin Nicolaescu-Musteață)So.....your saying do it on import, then LR/Tree export would duplicate the folder structure on export. Then, if desired, the user can empty the temp folder. The user then ends up with the edited photos in the desired folder structure.
Sounds a little bit convoluted, but it works. I guess with the LR3 and existing plugiuns that might be the only way to do it. If the user is only adding photos from a single month or two I suppose it would be easier to just generate the "month" folder manually.
3. Re: LR 3 - hierarchical export by date possible?
Dorin Nicolaescu-Musteață Oct 22, 2010 1:44 AM (in response to tplowe56)I create my structure on import and leave it untouched for the rest of the life of my pictures. My folder naming scheme is YYYY/YYMMDD - ShootName.
I use collections as temporary "work folders".
I can't see any benefit form moving files between folders once they are injected. But I do see potential troubles and risks.
