1 Reply Latest reply on Oct 20, 2010 12:44 PM by Thom Parker
    How to fill PDF form programatically
    Chinta_Pras Level 1
      Hi everyone,
      We are automating a web application using QuickTest Pro. In some scenarios we need to fill a PDF form and click 'submit' button. Is there any way we can use Acrobat SDK to automate this process? I really appreciate your help.
      Thanks and Regards,
      Kumar.
        • 1. Re: How to fill PDF form programatically
          Thom Parker Level 3
          Why Yes!  There are several ways to pre-fill a PDF.  Which technique depends on where the data comes from and where the PDF is going.
          For example, a PDF can be filled in Acrobat using an Acrobat data file such as FDF, XFDF, or XDP if it's a LiveCycle form.  This can be done manually through the menu items or automated with JavaScript, or with a batch process.  And there are lots of other variations on how data files can be used. Of this methodology assumes that the data file already exists.  The data file can be manually created by exporting data from Acrobat or automatically by some external custom program.
          Acrobat JavaScript can also used to access Excel and database files:
          http://www.pdfscripting.com/public/department48.cfm
          and LiveCycle forms can be connected directly to a DB.
          http://www.pdfscripting.com/public/34.cfm#XFADBForms
          Depending on the kind of data, JavaScript can be used to directly fill in forms.  This method is suiltable for handling a small number of fields, such as customer contact data.
          On the server side there is a whole host of third party tools for filling forms and of course Adobe has tools as well.  In fact PDF form data handling is built into ColdFusion.
          The Acrobat plug-in SDK has a Forms model for just this purpose and there is an ActiveX interface to Acrobat that can access individual form fields.
          Thom Parker
          The source for PDF Scripting Info
          pdfscripting.com
          The Acrobat JavaScript Reference, Use it Early and Often
          http://www.adobe.com/devnet/acrobat/javascript.html
          Then most important JavaScript Development tool in Acrobat
          The Console Window (Video tutorial)
          The Console Window(article)
