3 Replies Latest reply on Oct 20, 2010 2:16 PM by Todd_Kopriva
    When is it best to render OR media encode
    nyumeddei
      Adobe CS5  has the ability to encode AE comps and add to the queue without even having AE open. But i wonder what situations are better to render AE comps from the AE render queue or the standalone Media Encoder. Should a user expect better 64 bit performance from one? i know that codecs can limit that from happening, but i find that Media Encoder works all my processors into a frenzy when i render a comp from either AE or Premiere.
      Would love to know whats going on under the hood so i can streamline my workflow. I have been buoyed by my recent attempts to collapse transformations and pre-render, and i want to improve my efficiency even more.
        • 1. Re: When is it best to render OR media encode
          Todd_Kopriva Level 8
          There are pros and cons to using the standalone Adobe Media Encoder. See this page for an overview of the ways of rendering and exporting from After Effects, including using AME.
          One pro to using the standalone Adobe Media Encoder is that it can do two-pass encoding. So, if you're creating movies for final distribution and want to make them especially small, then you can use the standalone Adobe Media Encoder.
          One con to using the standalone Adobe Media Encoder is that it doesn't have the ability to set multiple output modules for one render item. Within After Effects, you can set multiple outputs for each render item, which means that the actual rendering operation only happens once, but the encoding/compression/writing output files can happen for multiple output types from one internally held set of rendered frames. Adobe Media Encoder can't do that; if you have five output types, then the compsotion will get rendered again for each.
          My workflow for creating F4V and FLV files is to render and export a losslessly encoded movie from After Effects, and have the destination for that output file be a watch folder. AME picks the item out of that watch folder and then compresses and encodes the FLV and F4V files according to the presets that I've set.
          • 2. Re: When is it best to render OR media encode
            nyumeddei Level 1
            Thanks as usual Todd for a quick response. What codecs do you prefer that are lossless? I am guessing you do not do image sequences in this watch folder technique  because how do you add the audio track?
            why do you think i see my processors all humming in unison using AME more than when i use AE to render?
            there is no out of the box  way (other than getting a third party solution) to have an AE background render, is there?
            • 3. Re: When is it best to render OR media encode
              I use the PNG codec in a QuickTime .mov wrapper.
              AME, BG Renderer, and Nucleo Pro are all good ways to render and export in the background while continuing to use After Effects in the foreground.
