4 Replies Latest reply on Oct 22, 2017 3:20 AM by peters93073162
    Sort bookmarks alphabetically
    jay fresno Level 2
      I have several major bookmarks and quite a few subbookmarks below each of the major bookmarks, and the subbookmarks need to be alphabetical within their major bookmark category. I've not been able to find a feature in Acrobat Pro that will sort bookmarks. Does anyone on this forum know of such a feature or can point me to a script that will sort bookmarks?
        • 1. Re: Sort bookmarks alphabetically
          DimitriM Level 3
          Hi Jay,
          There is no feature built-in to Acrobat for doing this, but it can be accomplished with a script.  While I have not tried it myself, here is a link for a bookmark sorting script ( I think you would  have to pay a fee for it)-
          http://try67.blogspot.com/2010/08/acrobat-sort-bookmarks.html
          Hope this helps,
          Dimitri
          WindJack Solutions
          www.windjack.com
          www.pdfscripting.com
          • 2. Re: Sort bookmarks alphabetically
            Milo G Level 1
            I also need to do this.
            Here is a script to collect bookmarks into an array and then sort them alphabetically. The big part that is missing is how to then put them back in the document. Hopefully someone here can fill in this missing step.
            /* Gather Bookmarks into an Array */
            // Begin job setup
            if ( typeof global.bmArray == "undefined" ) {
            global.indexCnt = 0;
            global.bmFileCnt = 0;
            global.bmArray = new Array();
            global.bmFileCnt++; // Count files
            // Get the path of the file Acrobat has taken from the selected folder
            var path2file = this.path;
            // Regular expression that acquires the base name of file
            var re = /.*\/|\.pdf$/ig;
            // filename is the base name of the file Acrobat is working on
            var filename = path2file.replace(re,"");
            // If the title is available, use it for a bookmark, else use filename
            if ((this.info.Title==null) || (this.info.Title.replace(/\s/g,"")==""))
            var bmToFile = filename;
            else
            var bmToFile = this.info.Title;
            global.bmArray[global.indexCnt] = [bmToFile,filename];
            global.indexCnt++;
            //Alphabetize bookmark list in array
            function compare (a,b) { // Define a compare function
            if (a[0] < b[0] ) return -1;
            if (a[0] > b[0] ) return 1;
            return 0;
            global.bmArray.sort(compare);
            • 3. Re: Sort bookmarks alphabetically
              bernst@fastline.com Level 1
              Milo, did you ever find a solution?
              • 4. Re: Sort bookmarks alphabetically
                peters93073162
                You can use the following script to sort the top level bookmarks alphabeticaly
                Author: Peter Slezak
                Date: 21OCT2017
                Description: Sort Top level Bookmarks alphabeticaly.
                var bm = this.bookmarkRoot;
                var newBmPosition1 = -1;  // this will hold new bookmark position in the top level bookmarkroot
                // Iterate through each top level bookmark
                var ibmLength = bm.children.length;
                for (var i = 0; i < ibmLength; i++)
                   console.println("Beginning processing of Bookmark original number = " + i + ", bookmark name = " + bm.children[i].name + " ...");
                   for(var j=0; j<i; j++){
                      if(bm.children[i].name <= bm.children[j].name){
                         newBmPosition1=j;
                         console.println("New Position Found = " + newBmPosition1 + " for " + bm.children[i].name);
                         break; // new position found, exit loop
                      else {  console.println("No Match Found in this loop - " + j + ", " + bm.children[i].name);   }
                   if (newBmPosition1>=0) {
                      bm.insertChild(bm.children[i], newBmPosition1);
                      newBmPosition1=-1;
                   else {console.println("No Match Found keep on the original position, " + bm.children[i].name);}
                   console.println("... End processing of Bookmark original number = " + i + ", bookmark name = " + bm.children[i].name);
