• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
checked boxes
New Here ,
Aug 08, 2007 Aug 08, 2007
howdy,
can someone help me with a check box issue plz?
i have i cfoutput of a list of categories from my category_table with check boxes next to them, i have another table CategoryToProduct and a session variable on the page which is the ProductID.
i want to have the check boxes checked if the productID matches in the CategoryToProduct table.
i have 2 queries but not sure how to join them to acheive what i need?
TOPICS
Advanced techniques
Views
889
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
First, rewrite your queries so that you are pulling category IDs. That's what is generally more useful than names in terms of form values. Plus, your second query could probably be a Q of Q.
Then, change this:
<input type="checkbox" name="checkbox"
value="checkbox"
checked>
to this
value="#SomethingFromYourQuery#"
<cfif listfind(ValueList(YourSecondQuery.somerow), SomethingFromYourFirstQuery) gt 0>
checked="checked"
</cfif>
Votes
Translate
Translate
Report
Report
New Here ,
ok thank you, i have changed the queries i think they are more appropriate, slightly different queries to what you surgested, but its not quite working
any ideas what i need to change?
Votes
Translate
Translate
Report
Report
LEGEND ,
Aug 14, 2007 Aug 14, 2007
I'm guessing that this
<cfif listfind(ValueList(get_Selected_Cats.CatID99), get_All_Cats.Cat_ID) gt 0>
checked="checked"
should be this
<cfif listfind(ValueList(get_All_Cats.Cat_ID)get_Selected_Cats.CatID99, ) gt 0>
checked="checked"
Votes
Translate
Translate
Report
Report
New Here ,
ok i have tried that but i get this error?
Invalid CFML construct found on line 49 at column 46.
ColdFusion was looking at the following text:
The CFML compiler was processing:
an expression beginning with "listfind", on line 49, column 7.This message is usually caused by a problem in the expressions structure.
a cfif tag beginning on line 49, column 2.
The error occurred in D:\httpdocs\EditPartsCategories.cfm: line 49
47 : <input type="checkbox" name="checkbox"
48 : value="#get_All_Cats.Cat_ID#"
49 : <cfif listfind(ValueList(get_All_Cats.Cat_ID)get_Selected_Cats.CatID99) gt 0>
50 : checked="checked"
51 :
Votes
Translate
Translate
Report
Report
Guest
Try placing a comma after (get_All_Cats.Cat_ID). BTW, if this is in a loop, you will be doing a ValueList( ) each pass through the loop. Better to place it outside the loop:
<CFSET foo = ValueList(Get_All_Cats.Cat_id)>
and refer to foo inside your loop.
Votes
Translate
Translate
Report
Report
New Here ,
ok i have tried that but now nothing the check boxes show but none of them are checked, as there should be.
this is inside a cfoutput query not a loop.
any ideas?
Votes
Translate
Translate
Report
Report
Guide ,
Dump the query and check the values of the checked column. Are any of them "Checked" or are they all an empty string ""
Votes
Translate
Translate
Report
Report
New Here ,
ok yes they are all set as empty string, but i know for a fact there should be atleast 2 boxes ticked that have a category link to the item i am viewing?
wierd?
Votes
Translate
Translate
Report
Report
Engaged ,
Here's a method where you let the database do the work in setting which input box is checked.
<cfquery name="catUnion" datasource="#application.ds#">
SELECT DISTINCT (CT.Cat_Name) AS Cat_Name, Cat_ID,'' as checked
FROM category_table CT
where CT.cat_id not in (
select catID99 from cattoprodcut where ProductID99 = '#session.ProductID#'
union all
SELECT DISTINCT (CT.Cat_Name) AS Cat_Name, Cat_ID,'CHECKED' as checked
where CT.cat_id in (
order by 1 ASC
</cfquery>
<cfoutput query="catUnion">
#catUnion.Cat_Name# <input type="checkbox" name="selCats" value="#catUnion.Cat_Id#" #catUnion.checked#><br/>
</cfoutput>
Votes
Translate
Translate
Report
Report
Guide ,
This half of the query should return the categories that are "checked". Run this query separately and dump it. Does it contain any results? If not, check the columns to see if the statement is correct. Also look at the sql statement debugging output to see what values were passed for #session.ProductID#
Votes
Translate
Translate
Report
Report
Guide ,
In case you're interested here's another sql option using a LEFT JOIN. Not tested but the syntax should work for MS SQL Server / MySql
Votes
Translate
Translate
Report
Report
New Here ,
Aug 15, 2007 Aug 15, 2007
Hi many thanks for your help i just have one more page of check boxes which needs the same checks but with a differnt query which is below.
i have the query below which shows my check boxes fine i need to add checks if RM.Product_ID64 = session.#session.part#
hope you can understand this, its a bit more complex
thanks once again
Votes
Translate
Translate
Report
Report
Guide ,
LATEST
You could try a variation of the query above. Again, not tested ..
Edit - on second thought perhaps all you need is INNER JOINs
Votes
Translate
Translate
Report
Report
Resources
Documentation
