3 Replies Latest reply on Oct 21, 2010 1:37 PM by Shongrunden
    Why does mouseOut of a DataGroup ItemRenderer cause a state change?
    ChrisInCambo2
      Hi guys,
      I've found a very annoying problem with the itemRenderers in a  DataGroup in flex 4, when I mouseout of the itemRenderer is returns to  its default state. Here's an example:
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <s:BorderContainer>
      <s:DataGroup>
      <s:layout>
      <s:VerticalLayout gap="1"/>
      </s:layout>
      <s:dataProvider>
      <s:ArrayCollection>
      <fx:Object title="One" />
      <fx:Object title="Two" />
      <fx:Object title="Three" />
      </s:ArrayCollection>
      </s:dataProvider>
      <s:itemRenderer>
      <fx:Component>
      <s:ItemRenderer>
      <s:states>
      <s:State name="expanded" />
      <s:State name="collapsed" />
      </s:states>
      <fx:Script>
                                      <![CDATA[
                                          private function expandCollapse():void
                                              currentState = (currentState == "collapsed") ? "expanded" : "collapsed";
      </fx:Script>
      <s:VGroup>
      <mx:Button click="expandCollapse();" label="Click me to hide the number" />
      <s:SkinnableContainer>
      <s:VGroup height="0" height.expanded="NaN">
      <s:Label text="{data.title}" />
      </s:VGroup>
      </s:SkinnableContainer>
      </s:VGroup>
      </s:ItemRenderer>
      </fx:Component>
      </s:itemRenderer>
      </s:DataGroup>
      </s:BorderContainer>
      </s:Application>
      When the user clicks on the button the VGroup is collapsed as  expected, but then if a user moves their mouse out of the item renderer  it then collapses, i.e. returns to its default state.
      Is this a bug or am I missing something here?
      Cheers,
      Chris
        • 1. Re: Why does mouseOut of a DataGroup ItemRenderer cause a state change?
          Claudiu Ursica Level 4
          By default ItemRenderers come with their own states and and they handle the
          MouseEvent.ROLL_OVER, MouseEvent.ROLL_OUT . Use a DataRenderr in your case since
          you don't need the normal and hover states anyway. I think you need to override
          the getCurrentRendererState to make it work somehow. I modified your example a
          little bit: I really hate inline renderes style of coding...
          TSTRenderer
          <s:DataRenderer
              <s:layout>
                  <s:VerticalLayout/>
              </s:layout>
              <s:states>
                  <s:State name="collapsed"/>
                  <s:State name="expanded"/>
              </s:states>
              <fx:Script>
                  <![CDATA[
                      import spark.skins.spark.DefaultItemRenderer;
                      protected function stateBtn_clickHandler(event:MouseEvent):void
          "collapsed";
              </fx:Script>
              <s:Button id="stateBtn" click="stateBtn_clickHandler(event)" label="Click me
          to hide the number"/>
              <s:Label
                  includeIn="expanded"
                  text="{data.title}"/>
          </s:DataRenderer>
          <s:Application
              <s:BorderContainer>
                  <s:DataGroup itemRenderer="TSTRenderer">
                      <s:layout>
                      </s:layout>
                      <s:dataProvider>
                          <s:ArrayCollection>
                      </s:dataProvider>
                  </s:DataGroup>
          </s:Application>
          C
          • 2. Re: Why does mouseOut of a DataGroup ItemRenderer cause a state change?
            ChrisInCambo2 Level 1
            Thanks for the reply, that fixed the problem. I do usually seperate my item renderers but always put them together when posting in forums so it's easy to copy, paste and compile.
            I've only just started learning Flex 4 and skinning components so states are fresh in my mind and I thought that they might be part of the problem, but when I checked the ItemRenderer in the docs there was no mention of any states. Now I've taken a closer look, I've realised that none of the components mention their internal states, do you know where I can look to find out what states various components in Flex 4 have?
            • 3. Re: Why does mouseOut of a DataGroup ItemRenderer cause a state change?
              Shongrunden Adobe Employee
              Take a look at the code in the getCurrentRendererState() method of the spark.components.supportClasses.ItemRenderer class to see when renderers are put into what states.
              An ItemRenderer in a DataGorup will go into either the "normal" or "hovered" state, whereas in a List it will go into either a "normal", "hovered", "selected", etc. state.
              This post might also be useful: http://flexponential.com/2010/02/07/using-datarenderer-to-add-custom-states-to-a-spark-lis t-renderer/
