3 Replies Latest reply on Oct 21, 2010 10:31 AM by Steve Grisetti
    Project settings problem
    mundenbar Level 1
      This started out as a sound issue and now it is a whole different ball game.
      Recently when I shared my video and converted it into the MPEG foramt, the sound was gone.
      I did some checking and I saw that the porject settings were at HDV 1080i.
      So I started a new project at the setting of HD 1080I. No V.
      I run into the same sound problem again. The strange thing is that the project settings have been changed to HDV 1080i.
      Is there anyway to change the project settings after a project has been created? I go to Project setings but I am unable to do it.
        • 1. Re: Project settings problem
          mundenbar Level 1
          I just played around with the new project settings, Something strange is going on. I place the settings at
          HD 1080i 5.1 Channle and the project settigns now are HD 1080i.
          • 2. Re: Project settings problem
            the_wine_snob Level 9
            Going back to the original Project, when you selected the Share settings, what did you choose in the Multiplexing tab?
            With most Share options, one has three things that they must do to get a muxed file, i.e. combined Audio and Video streams: Select Export/Share Video, Export/Share Audio and then Multiplexing set to another setting besides "None." All three of those must be set.
            Now, with your Project Settings, what are the full specs. of your source footage? That will determine your Project Preset, as they must match.
            What version of PrE do you have?
            One can alter Project settings, once the Project has been started, but it involves hacking the PREL (Project) file, and it's almost always better to start the Project with the proper settings.
            • 3. Re: Project settings problem
              Also, do make sure when you begin your Premiere Elements project that you set it up with the correct project settings.
              The HDV preset you are using is for tape-based hi-definition video captured over a FireWire connection.
              Is that where your video is coming from?
              If it's from another kind of camcorder -- particularly if it's from an AVCHD hard drive camcorder shooting in 5.1 audio -- this could explain your problem.
