0 Replies Latest reply on Oct 21, 2010 12:59 PM by knallore_adobe
    [svn:fx-4.x] 18267: Merge revision 18165 from hero_private to 4.x.
    knallore_adobe
      Revision: 18267
      Revision: 18267
      Author:   knallore@adobe.com
      Date:     2010-10-21 11:02:23 -0700 (Thu, 21 Oct 2010)
      Log Message:
      Bug: Watson 2738778 - DataService got disconnected from it first request after the channelSet had logged in
      QA: Not yet
      Doc: No
      Checkintests: Pass
      Details: This is rpc.swc part of the fix. This fixes the following problems:
      - When client needs config, it disconnects the channel even though channel is connected.
      - After disconnect, channel hunting kicks in, and fallback to the next channel happens, even though the first channel is fine.
      - Trigger_Connect is acknowledged locally even though the client needs config.
      Tests run: Verified that the rpc.swc built successfully
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/rpc/src/mx/messaging/ChannelSet.as
